It is currently Wed Sep 30, 2026 10:16 am
Post Posted: Wed May 23, 2012 12:29 pm
HI, been looking for a WT jack shaft, only able to find a NT so far. I have been thinking, Whats the difference? I know that you can swap around flangs between W/T and NT 1.3 shafts as they have the same uni's. What about the Jimny? Would I be able to swap the Jimny flanges with the NT............?
This is for the Sierra transfer conversion to my 2002 M13A Non-VVT Jimny :)
Vehicle: 1985 lwb sierra UTE
Post Posted: Wed May 23, 2012 3:02 pm
the rear shaft is slightly longer u can get away with just changeing the end bits that bolt ont the diff pinon or change ur diff pinion
Green? greeeen is nice !
Vehicle: 03 Jimny
Post Posted: Wed May 23, 2012 3:07 pm
Wt flanges on shaft and diff centers are same as Jimny. If Jimny uni are the same as wt sierra, you should be able to take the flange of the Jimny jack shaft and and put it on the nt 1.3 jack shaft. This should allow you to use te nt 1.3 shaft for the conversion.
Post Posted: Wed May 23, 2012 5:10 pm
pretty mmuch what iv done they didnt seem to vibrate i didnt even remove the whole shaft
Post Posted: Thu May 24, 2012 12:28 pm
This is about the jack-shaft (between the transfer ans gearbox).
Users browsing this forum: No registered users and 133 guests
