It is currently Thu Aug 06, 2026 5:26 pm
Vehicle: 1.3 Tin Top
Post Posted: Thu May 24, 2012 8:08 pm
I have just set up a hand throttle in my sierra. its a choke unit of an old subara wagon.
Pull the knob to set your rpm then flick a switch to lock it.
There is an electro-magnetic clamp inside the unit which locks the cable in place, flick the switch off and the throttle returns to idle.
Im pretty happy with it although its pretty hard to pull the knob so i just have to use my right foot to assist.
Has anyone else got something similar or any other hand throttle set up?
I havnt fitted a switch yet but u can see where it will go.
Whats hiding behind the dash, this box contains the electromagnetic clamp. there is also a light trigger. so i could rig a dash light.
The cable is a little long so i ran it along the dash rail then back to the right hand side of the dash and down to the pedal.
this is wear the cable attaches.
Ensure to leave slack at idle so the knob does not affect normal idle speed.
This is full throttle.
i just took the accelerator cable off slid the choke cable in between the two plates and put the accel cable back on.
Post Posted: Thu May 24, 2012 8:27 pm
I've got gears so am on the upper end of the rev range usually.
I have seen a hand throttle setup that was an old Victa chrome throttle lever and cable mounted on the gearstick like a truck range/splitter switch.
Post Posted: Thu May 24, 2012 8:40 pm
I mainly got it so i set a fast idle for my air comp. but it will help with warm ups on cold mornings and it will mean i dont get throttle bobble offroad.
to remove any confusion i can set it anywhere from idle to red line
Post Posted: Thu May 24, 2012 8:57 pm
I ran a cable to the idle up part of carby.
Used the 1.o litre choke cable already fitted,
as I'd upgraded to 1.3 donk.
Post Posted: Thu May 24, 2012 9:07 pm
i've been meaning to hook one up in my Vitara for the last 6 years.... might actually get around to it soon, will be using the guts from a MTB grip shifter as the gear knob on either the transfer or gear stick rather than having a dicky odd looking lever in a late model interior.
Post Posted: Thu May 24, 2012 9:15 pm
EFI could be electonically switched to idle up
Post Posted: Thu May 24, 2012 9:18 pm
That would be sweet like the throttles on Cat 1 tanker pumps.
they have a linear actuator but the throttle is a n rtc toggle switch each flick is 100rpm.
Post Posted: Thu May 24, 2012 9:32 pm
On a Vit, I think headlights, air con and temp all cause idle up,
so it could be done.
On my Sierra, I needed it for stall prevention, hill starts and stuff,
because of a dicky clutch leg.
I not so worried on me Vit as its auto.
But if need arises, will go switched hi idle, rather than full hand throttle
Post Posted: Fri May 25, 2012 6:58 am
Vit has PS idle up too.
Post Posted: Fri May 25, 2012 5:29 pm
Does Vit idle up work off a load sensor? my xtrail has load sensitive idle, so its pretty dificult to stall unless ur trying, you can almost drive with out using the right pedal at all :lol:
Post Posted: Fri May 25, 2012 6:44 pm
My G16B has an anti stall idle up but I have absolutely no idea where it is or how it works. Never bothered to find out cause it still works.
Post Posted: Fri May 25, 2012 6:57 pm
Just flick you parker lights on, this will bring on your ideal up, then set that you to where you want ir
Post Posted: Sat May 26, 2012 12:03 pm
there would be limitations though with the throttle body being completley closed? i suspect a mechanical/magnetic solution would be better.
Is there something avail where you can just set it with your foot and flick a switch to activate an electromagnet style clamp or similar? (just spitballing here)
MY BUILD THREAD HERE!!!!!
Post Posted: Sat May 26, 2012 12:40 pm
Thats almost exactly what i have rigged up Scales. though it uses a knob. but pulling the knob does actually depress the pedal.
Post Posted: Sat May 26, 2012 12:45 pm
You could always go to the wreckers and get an idle up cable/knob thingo out of a GQ for a few dollars. Not a high demand item so they'd be dirt cheap.
Would look like a factory install too.
Post Posted: Sat May 26, 2012 1:51 pm
can you put up a pic of the vitals dude? how it attaches etc? this has peaked my interest.
Post Posted: Sat May 26, 2012 5:38 pm
sure can. give me an hour or so
Users browsing this forum: Google [Bot] and 722 guests
