https://auszookers.com/forum/
86 Sierra
https://auszookers.com/forum/viewtopic.php?f=5&t=32899
Author:  Cameron2317 [ Sat May 26, 2012 5:04 pm ]
Post subject:  86 Sierra
My 1986 Sierra won't start, it was running rough before it died. I have fuel, air but no spark, I have replaced the coil, points, condenser, rotor button, cap, leads and plugs. Is their anyone who can help me?
Author:  abclarke [ Sat May 26, 2012 5:12 pm ]
Post subject:  Re: 86 Sierra
Tried another battery or checked the terminals?
Author:  Scrawny [ Sat May 26, 2012 5:15 pm ]
What motor? I thought all G13's were electronic (no points)?
Author:  want33s [ Sat May 26, 2012 5:34 pm ]
I call BULLSHIT... You couldn't have replaced the points or condensor..
Scrawny is right 1.3's are all electronic and there were no 1.0 Sierra's or Maruti's in 86.
Author:  Cameron2317 [ Sat May 26, 2012 5:42 pm ]
It's a f10a so no it's not electronic
Author:  Cameron2317 [ Sat May 26, 2012 5:43 pm ]
Battery and terminals are new
Author:  want33s [ Sat May 26, 2012 5:48 pm ]
F10a in 86... :?
OK..
Is there power into and out of the ballast resistor and if so what voltages?
Author:  Cameron2317 [ Sat May 26, 2012 5:53 pm ]
Yeah I was shocked at first when I saw it was a f10a. Stupid question but is the ballast resistor sitting above the coil, if so then no their is nothing
Author:  want33s [ Sat May 26, 2012 6:58 pm ]
Ballast is normally mounted on coil or close to it.
No power to the ballast means you need to look a bit further to see if there is power at the ignition switch.
Run a wire from battery + to the ballast and see if the car starts. This will at least tell you that everything from the ballast to the spark plugs is working.
Author:  Cameron2317 [ Fri Jun 01, 2012 11:35 pm ]
Just curious, but I'm still getting spark at the points. Anyone have any ideas.
Author:  want33s [ Sat Jun 02, 2012 9:28 am ]
You said earlier you have no power at the ballast...
If there is no power into or out of the ballast there will be NO spark at the points.
Author:  Cameron2317 [ Sat Jun 02, 2012 12:09 pm ]
Solved that there was a dirty wire so I replaced it and got power. Now I'm back to square one
Author:  want33s [ Sat Jun 02, 2012 1:19 pm ]
If you have spark at the points you can test the coil by removing the coil lead from the dissy cap and place it near an earth.
Reove dissy cap , turn ignition on and turn engine so points are closed. Flick them open with a paddle pop stick or similar and you should get a spark out of the coil lead.
As far as it not running...
What is the point gap set at?
Are the points burned/pitted?
Is the spring button for the rotor in good nic?
Author:  Cameron2317 [ Sat Jun 02, 2012 3:40 pm ]
Thanks mate will try that and will let you know how it goes.
