It is currently Sat Nov 07, 2026 4:40 pm
Post Posted: Mon Jun 11, 2012 7:35 pm
brought the n/t case n 6,5 gears installed. where would i buy brackets to get it to fit in the car? or how can you get it to fit?
Post Posted: Mon Jun 11, 2012 7:42 pm
Change the flanges to WT, you will also need the transfer arms and jack shaft from a WT Sierra. BenT's arms in the buisness section are a very good upgradable option :wink:
Post Posted: Mon Jun 11, 2012 7:46 pm
ok awsome thnx. ill look for bents arms. my flanges will go straight on to the n/t transfer??
Post Posted: Mon Jun 11, 2012 7:49 pm
The hole centre's are different from NT to WT/Coily
Post Posted: Mon Jun 11, 2012 7:58 pm
sorry bout all the queastions.
so need to find leafy W/T flanges?
n is the the mount kit >>>Transfer Lift Mount Kits?
Post Posted: Mon Jun 11, 2012 8:00 pm
Second last product
viewtopic.php?f=15&t=15009
Post Posted: Mon Jun 11, 2012 8:03 pm
Yep...and the jack shaft. What he said ^^^^^
Post Posted: Mon Jun 11, 2012 8:24 pm
ok thnx for the help. any idea where i could buy jack shaft n w.t flanges?
Post Posted: Mon Jun 11, 2012 8:27 pm
Shaft is reasonably easy to get. WT flanges can be harder. Put a wanted add up and try your luck :peaceout:
Post Posted: Mon Jun 11, 2012 8:32 pm
awsome thnx again'
Users browsing this forum: Google [Bot] and 51 guests
