It is currently Wed Nov 11, 2026 9:41 am
Post Posted: Mon May 28, 2012 5:00 pm
Hi all i was wondering if anyone knew what could be wrong and why my sierra wont start it has a new starter motor im it. Okay here is what it is doing, when i turn the key it wines over but wont kick overand start it just keeps winding. I was wondering if anyone knew what it could be cheers.
Post Posted: Mon May 28, 2012 5:05 pm
Checked your Fuel and spark?
Pull the fuel line off the carby and turn the key to check if it's pumping fuel.
Pull your leads off the plugs and see if they're arcing.
Post Posted: Mon May 28, 2012 5:47 pm
Yup i have checked the fuel and spark. And it is pumping fuel into carby and also have good spark
Vehicle: Clown Car..
Post Posted: Mon May 28, 2012 6:02 pm
is the starter actually turning the motor over or is it just spinning on what maybe a shagged tooth on the flywheel!?
Tried rolling the car forward, backward in gear and trying again if this is the case!??
Post Posted: Mon May 28, 2012 6:06 pm
Pull your spark plugs out to see if they are dirty. Give them a clean while they are out.
Post Posted: Mon May 28, 2012 8:21 pm
The car turns over when the key is turned but doesn't start and keeps cranking when the key is turned off.
I am going to haurp00ned's place in the morning with another starter.
Post Posted: Mon May 28, 2012 8:23 pm
I call a stuffed starter.
Users browsing this forum: No registered users and 113 guests
