It is currently Sat Nov 07, 2026 7:27 pm
Vehicle: 1995 swb vitara
Post Posted: Wed May 30, 2012 10:25 am
Has anyone used or tryed Lovell raised springs in a swb vitara
Any feedback would be appreciated as I am looking into a set
The price is right , but personally never used lovells before
They claim 30mm lift
Vehicle: 1991 suzuki vitara jlx
Post Posted: Thu May 31, 2012 12:04 am
Hey mate, put them in my 91 vitara a couple of months ago. I got a decent amount of height from them, but was in a rush so didn’t take any measurements :( They ride a bit rough on the standard vitara wheels and you will definitely need adjustable front camber bolts.
Post Posted: Thu May 31, 2012 6:49 am
Thanks , I have camber bolts in at moment with flipped strut tops and 15mm front + 30mm rear spacers , and will remove these when springs go in ,,, got commo shocks on rear ,, did you have to put a tailshaft spacer in ? Or any others like brake lines etc ?
Post Posted: Thu May 31, 2012 1:28 pm
Drive shaft and brake lines should be OK with a 30mm lift.
Unclip the front lines from the point where they mount to the body (the next one upstream from the strut, next to the top of the spring):
If your rears get tight at full droop you can release them from the control arm retainer and/or the clip on the chassis:
Post Posted: Mon Jun 04, 2012 8:06 am
Cheers for the info / will post before and after when they arrive .
Users browsing this forum: Google [Bot] and 52 guests
