It is currently Sat Nov 07, 2026 5:36 pm
Vehicle: 1999 Jimny
Post Posted: Sun Jun 10, 2012 5:05 pm
Was wondering since there is no plug leads as such, how the fug do I check the timing :?
Have fixed the O2 sensor, should the light bugger off by itself :?:
Note; Oxygen sensor was done from the top & easier with the heat shield off exhaust manifold( for those who are yet to do one).
Post Posted: Sun Jun 10, 2012 5:09 pm
Have you tried disconnecting the battery?
Timing is all controlled by the computer
Vehicle: 1999 Jimny
Post Posted: Sun Jun 10, 2012 5:19 pm
The manual says timing should be at 10 degrees & it has all the shizzle for it on the timing cover.
Disconnected the flattery for 45 mins I guess it has to be longer.
Post Posted: Sun Jun 10, 2012 5:53 pm
What was the O2 sensor fault from the code reader? O2 output to high or output too low? You may have a leak/crack in the exhaust manifold possibly causing the O2 sensor to still read erratic and re-trigger the check light
Lil Foot!
Vehicle: 1999 Jimny
Post Posted: Sun Jun 10, 2012 6:16 pm
The reading was to lean followed by a to a to rich. It is running smooth as silk now so I will at some point get it read again this time I will pay with rum!! ; ) lol.
Post Posted: Sun Jun 10, 2012 7:55 pm
Shouldn't need more than 10-15mins to reset. It may also have an intake leak
Vehicle: 1999 Jimny
Post Posted: Sun Jun 10, 2012 9:47 pm
We had a look at the graph on the scan tool & it showed us the MAF, both O2 sensors & you could definitely see the bad one. But I will be keen to see what we get when I check it again.
Vehicle: lj81 stockman
Post Posted: Sun Jun 10, 2012 10:23 pm
Anytime let me no and we can have a nother look
the wobble rocks
Post Posted: Mon Jun 11, 2012 5:19 am
If you pull back the sheath over the coil pack wiring, you'll find three wires, +12V switched, coil pack drive & ground - clip the inductive pick up over either the +12V switched or ground (choose one of the outside wires) and see it it flashes (mine does) - there should be a notch in the crankshaft pulley and a mark on the timing cover.
Post Posted: Mon Jun 11, 2012 7:28 am
If it doesn't have a distrubter, you can't adjust the timing, so there is no point being able to check it. Timing is taken care of by the ecu.
Vehicle: 1999 Jimny
Post Posted: Mon Jun 11, 2012 5:11 pm
It has a distributor!!!!!!!!!!!!!!
Will give your Idea a go thanks fordem.
Post Posted: Mon Jun 11, 2012 5:31 pm
A distributor but no leads? :?
Vehicle: 1999 Jimny
Post Posted: Mon Jun 11, 2012 5:34 pm
strange huh!!
Post Posted: Mon Jun 11, 2012 6:27 pm
Does it just have a cam sensor in it?
Post Posted: Mon Jun 11, 2012 6:33 pm
^^yep
Lil Foot!
Is it adjustable then?
Vehicle: 1999 Jimny
Post Posted: Mon Jun 11, 2012 6:58 pm
It has adjustment on it, the manual says it has to be set at 10 degrees, so fucks me batman........... Guess I need to have a look out of curiosity.
Post Posted: Tue Jun 12, 2012 2:47 am
The ECU handles the dynamic advance based on vacuum and rpm, but there's a base advance which is set using the cam position sensor, and it is adjustable. There's a jumper that needs to be inserted to "lock" the ecu advance - check www.Rhinopower.org for the specifics.
Users browsing this forum: Google [Bot] and 80 guests
