It is currently Sun Nov 08, 2026 10:56 pm
Vehicle: 03 Jimny
Post Posted: Tue Jun 12, 2012 8:13 pm
all i no is they have 4.1 diffs and run a f10a engine.
are all diff components same as sierra wt?
are transfer case a 1lt or 1.3? same ratios as wt? can reduction gears fit?
can lockers fit and cromos fit? 26 rear and 22 spline front?
any thing else i should no comparing it to a wt sierra?
cheers
Post Posted: Tue Jun 12, 2012 9:09 pm
are all diff components same as sierra wt? WT marutis are ( except for the pinion flange)
are transfer case a 1lt or 1.3? same ratios as wt? can reduction gears fit? They are 1L ratios. The case is identicle to any 1.3L case, so gears will fit.
can lockers fit and cromos fit? 26 rear and 22 spline front? Yes, aslong as its a WT maruti.
any thing else i should no comparing it to a wt sierra? Material quality is lower than jap made sierras, so fatigue will set in a little earlier. Otherwise, they are just as good as any other sierra.
cheers
Vehicle: 03 Jimny
Post Posted: Wed Jun 13, 2012 1:04 am
Thanks Pete
Users browsing this forum: No registered users and 99 guests
