It is currently Sat Nov 07, 2026 11:57 am
Vehicle: 2003 Jimny Auto
Post Posted: Wed Jun 13, 2012 9:07 pm
I have seen some people undoing a radius arm bolt to help flex up onto ramps etc
Does anyone drive like this? Is it safe? Pros and cons?
Vehicle: 03 Jimny
Post Posted: Wed Jun 13, 2012 9:29 pm
when i did it i couldnt really drive with out my unis binding
Vehicle: Suzuki Jimny 2009
Post Posted: Wed Jun 13, 2012 9:49 pm
No you cannot drive it like that. The axle will twist as zooky08 said.
Post Posted: Wed Jun 13, 2012 10:12 pm
Depends on the car. But apparently on a jimny it's a no no, as above
Post Posted: Wed Jun 13, 2012 10:32 pm
I have lost a radius a bolt over 100km's from home out on a night trip before and apart from the extra body roll ( not much roll stiffness with a bolt pulled) it drove fine. The axle will twist if you have 2 bolt's pulled on the same axle, but it shouldn't twist with only one bolt pulled. I don't recommend pulling a bolt if you are driving on road tho....
Here's a few pics of the amount of flex to be had with a bolt pulled...
That was one rear bolt pulled...
And that's a front bolt pulled...
And that's not bolt pulled.
I noticed alot more flex was gained in the rear by having a bolt pulled over the front, and it felt more stable having a rear bolt pulled over the front. Not much gain in having a front bolt pulled IMO
Vehicle: SJ80, SE416
Post Posted: Thu Jun 14, 2012 10:01 am
With the number of Suzuki Jimny's and coil Sierras that break radius arm mounts on the diff, i'd never want to remove any radius arm bolt to 'increase flex' ever.
Does anyone drive like this? NO. Is it safe. Hell no.
Post Posted: Thu Jun 14, 2012 1:11 pm
Thx everyone
Monley are you using standard arms? Do you think releasing a rear bolt is worthwhile? (Would you bother doing it for a 4x4 trip)
Post Posted: Thu Jun 14, 2012 1:58 pm
Lockers are more worthwhile than the flex you'll get from pulling a bolt.
Post Posted: Thu Jun 14, 2012 2:12 pm
No doubt. At $1000s of bucks it had wanna be!
I'm not saying i'll pull a bolt, was just interested when I saw others taking photos of flex with it out
Vehicle: 03 Jimny
Post Posted: Thu Jun 14, 2012 2:48 pm
Worse is reversing with to bolts pulled, unis go clunk clunk.
Here is a pic of just the rear bolts pull. Doing this doesn't let the front suspension work
Post Posted: Thu Jun 14, 2012 3:18 pm
You pulled BOTH?
Vehicle: 03 Jimny
Post Posted: Thu Jun 14, 2012 3:23 pm
1 bolt either side is pulled in the rear, none in the front
Post Posted: Thu Jun 14, 2012 5:27 pm
I'd be very careful about pulling bolts - Its murder on mounts, and it does nasty things to handling.
Monley has been running bolts pulled for a while AFAIK, and this is what one of his mounts look like. With one rear bolt pulled, you are doubling the drive load on the mount that doesn't have a bolt pulled.
Also, depending on what side has been pulled and which way your car is leaning when you try to drive something, you can have the suspension go to full droop on one side under light throttle and a small side angle. I've experienced this when I was experimenting with pulled bolts. I lost lots of capability on hill climbs because the car just flopped over really severely under power, far worse than with a three link, because the drive load is trying to open the suspension up with a radius arm, and once all that force is applied to only one side of the car, things get out of hand.
Pulled bolts are fine for posing, or for ramping your car to check clearances etc, but it's not for driving obstacles.
Steve
Post Posted: Thu Jun 14, 2012 5:46 pm
Steve
That damage was caused by a flogged out bush and a LOOSE bolt (2-3 days of with a loose bolt in fact :o ) . Not from having a bolt pulled. I have not ran for longer than 1 day with having a bolt pulled :roll:
I have only ran for one trip with a front bolt pulled (just to see how much flex was gained) and no time's in the rear on purpose. When i don't have a bolt in the rear it's always been from vibration's making the bolt loose and coming out it's self .
Post Posted: Thu Jun 14, 2012 5:50 pm
Yeah, that's retarded.
Post Posted: Thu Jun 14, 2012 5:51 pm
I stand corrected, but I'll stand by my comments. Run with a bolt pulled for long and that's what the mounts will look like. They're not strong enough stock, let alone with twice the force going through them. The floggedness of the bush has nothing to do with it.
Vehicle: 03 Jimny
Post Posted: Thu Jun 14, 2012 5:53 pm
was on my property and was getting dark so i only did the rear and drove 10 metres up a dirt pile. not retarded
if i had more day light of course i would do the front as well and before you ask was geting dark, but that photo is edited.
Post Posted: Thu Jun 14, 2012 9:44 pm
None of that made it any less retarded..
Post Posted: Fri Jun 15, 2012 7:18 am
Pulling a bolt either side... What's stopping the diff from twisting under power and brake? I wouldn't be doing that...
Post Posted: Fri Jun 15, 2012 10:33 am
Lol probs the panhard trying to hold everything in place
Lil Foot!
http://tiny.cc/gtsw1
Vehicle: 03 Jimny
Post Posted: Fri Jun 15, 2012 3:02 pm
I thought I did what monley said to do, maybe I mis read what he said
I still had two other radius arm bolts in plus shocks and panhard, and drove 10 meters max very slowly.
Post Posted: Fri Jun 15, 2012 3:24 pm
Only one bolt each end so 2 in total not 4 out of 8
Post Posted: Fri Jun 15, 2012 3:32 pm
Yeah. Usually you do one long side bolt.
Vehicle: 03 Jimny
Post Posted: Fri Jun 15, 2012 4:30 pm
Oh I see oops I only pulled two in rear not 4, but I did drive slowly so I didnt do any damage. Was only once for a poser shot .
Post Posted: Sat Jun 16, 2012 6:14 am
Ur so lucky
If u put any power into it it would have shattered ur tail shaft as the diff would have just spun backwards
Vehicle: 03 Jimny
Post Posted: Sat Jun 16, 2012 7:54 am
If I gave it alot of power it would have but for me to get up the dirt pile the shocks and panhard rod held it from turning to much
Vehicle: 1985 lwb sierra UTE
Post Posted: Thu Jun 21, 2012 6:10 pm
did u just try it for arguments sake or do u drive it like that?
Green? greeeen is nice !
Users browsing this forum: No registered users and 63 guests
