https://auszookers.com/forum/
Make a noise suppressor???
https://auszookers.com/forum/viewtopic.php?f=5&t=33414
Page 1 of 2
Author:  gvzookdriver [ Thu Jun 14, 2012 8:02 pm ]
Post subject:  Make a noise suppressor???
OK well i have printed off i wiring diagram that matches my wiring harness but i am missing the noise suppressor.
I have been to the wreckers in Brisbane and Darwin but they don't have any G16B engine with the noise suppressor still attached. I have also rang suziworld and suzistore to see if they can help but they cant :cry:
Now my BIG question is - Is it possible to to make a noise suppressor ?? Going by the diagram it is only a resistor and 2 capacitors (from memory don't currently have the schismatic in front of me). But i am unsure of the values of all of these. I have had a quick search of the net to try and find out what they are but can not find them.
Peter
Author:  Blakey [ Thu Jun 14, 2012 8:42 pm ]
Post subject:  Re: Make a noise suppressor???
just chuck in some Capacitors. anywhere from pF to mF what ever your willing to pay. if its for noise better to go smaller so you don't get to large a current fluctuation.
you will need one that is a able to take a max voltage spike on the system so like 20V or higher capacitor. larger the F the more current they store. also the slower they suppress Voltage difference. ie change in voltage.
you want them to be installed from positive to negative. to remove or smooth out your DC wave, especally cause your coilpacks cause your nice flat DC battery wave to be pretty sperodic. the capacitor smooths it back out.
but also on that i doubt it will be a resistor and capacitor rather it would mostlikly be an inductor. as a resistor does nothing for electrical noise where as a capacitor and an inductor does. but i wouldn't worry with the inductor as if you use to large of inductor you can cause huge voltage spikes to go through your system destroying things. plus if you overload them they just become a dead short anyway. so might as well not be there.
Also
I Think REPCO or SUPERCHEAP sell them might be good to just buy a pre made one also (do not buy an INLINE noise suppressor ) they are bad very bad. do not do it.
Author:  gvzookdriver [ Thu Jun 14, 2012 9:14 pm ]
Ill check them both tomorrow ? so i can just buy any noise suppressor (not in line) and it should work
Also i found this if it help
http://www.suzuki-forums.com/suzuki-sid ... ilter.html
Author:  fordem [ Fri Jun 15, 2012 12:33 am ]
Have you ever seen or worked this particular noise suppressor?
Among other things it provides a pulse train to the tachometer and "ignition event" feedback to the ECU, without which the ECU disables injection.
Author:  Blakey [ Fri Jun 15, 2012 9:23 am ]
not much of a noise supressor if its for providing a pulse. especally considering a capacitor cant provide a pulse. it charges up and thats it.
the only way it can provide a pulse is if its couppled with a timer such as a 555. then yes it will use a capacitor or 2 and a resistor or 2 to determine a square wave pulse width.
not to mention an electronic tacho gets its pulse from a sensor that is on a toothed gear on the output shaft. there is no need for a noise supressor there as it will ruin the pulsed output from the sensor.
Author:  Blakey [ Fri Jun 15, 2012 9:58 am ]
but from reading that, it seems the resistor is not part of the noise supressor its just show with it. the caps are still just normal capacitors used for supressing noise. and the resistor is for a feedback from the coil. as it says just use a 2kish ohm resistor for the feedback and use a bought noise supressor for the capacitors.
Author:  JrZook [ Fri Jun 15, 2012 10:30 am ]
Huh? :?
The noise filter/suppressor seems to be a resistor/capacitor low pass filtering circuit. It filters out the high frequency noise out from the coil ringing after it has fired to provide stable pulses for the ECU to read for coil/ignition feedback.
GV according to that link and the wiring diagram on suzukiinfo on the late model 1.6 (which i assume you have) the 2.2kohm resistor provides the ignition fail safe signal from the coil negative to the ECU pin B6.
I can try and measure the capacitors on mine over the weekend to see if I can get there values for you.
Author:  fordem [ Fri Jun 15, 2012 10:44 am ]
I'll take that as a NO - and I'm going to guess you haven't worked with too many electronic tachometers either - for what it's worth, most electronic tachometers on gasolene engines count the pulses when the plugs fire - no sensor and no toothed gears.
Author:  Blakey [ Fri Jun 15, 2012 10:49 am ]
Huh? :?
lol electronics. i wouldnt worry to much about it.
but yes the capacitors filter out the high freq they do not require a resistor to filter, the resitor isnt really part of the noise supressor. its just part of that whole item.
Author:  JrZook [ Fri Jun 15, 2012 10:58 am ]
Ever heard of a RC low pass filter?
Author:  Blakey [ Fri Jun 15, 2012 11:00 am ]
come to think of it i was thinking of a speedo. but still the capacitor does nothing to do that. it is not used for pulses. as it they do not work like that. capacitors are purely for noise supression, Stabalizing Voltage , and storage of potential.
Author:  gvzookdriver [ Fri Jun 15, 2012 8:11 pm ]
Jr Yeah i have a late model 1.6. That would be AWESOME if you could figure out the capacitors :D then i could just make my own little noise suppressor to get the car up and running till i can find a factory one Armsup
Author:  Blakey [ Fri Jun 15, 2012 9:53 pm ]
That is for AC completely different effects to capacitors on DC. Capacitors block DC that's why they work as noise suppression on a dc. As it removes Any AC component or smooths fluctuating DC potential leaving a smoother DC wave.
Author:  JrZook [ Fri Jun 15, 2012 10:03 pm ]
Blakey the coil negative which the suppressor is connected to has coil ringing and high frequency noise on it from the back EMF produced from the coil. This can be regarded as 'AC' as its a high frequency fluctuation in voltage.
Author:  Rhinoman [ Sat Jun 16, 2012 7:44 am ]
I'm pretty sure that the spec for the noise suppressor is in one of the FSMs, they are common to pretty much all of the EFi Suzukis up to around 1998. I'll I'll take a look and see what I can find.
If I can't find it I'll measure mine on Monday.
Author:  Rhinoman [ Sat Jun 16, 2012 7:56 am ]
That makes no sense whatsoever.
Author:  gvzookdriver [ Sun Jun 17, 2012 8:24 pm ]
So did anyone get to measure there noise suppressor ??
Author:  Rhinoman [ Mon Jun 18, 2012 3:18 am ]
I'll do it tomorrow, I need to put it on a bridge.
Author:  gvzookdriver [ Mon Jun 18, 2012 7:06 am ]
Author:  Rhinoman [ Mon Jun 18, 2012 7:08 pm ]
This is what I measured it as:
Author:  gvzookdriver [ Mon Jun 18, 2012 7:48 pm ]
AWESOME thanks sooooooo much for that. Now lets hope that jaycar has those size capacitors and resistors :)
Author:  Rhinoman [ Mon Jun 18, 2012 9:05 pm ]
I forgot to mention that the coil negative is usually clamped at around 400V so you will need to ensure that your components are adequately rated. On the ign+ side you will see a lot of noise but 100V should be adequate.
Author:  gvzookdriver [ Mon Jun 18, 2012 10:06 pm ]
So R1 and C1 need to be rated to 400v DC ??
Author:  Rhinoman [ Mon Jun 18, 2012 10:13 pm ]
Call it 500V and you should be good.
Author:  gvzookdriver [ Mon Jun 18, 2012 10:48 pm ]
Thanks sooooo much for your help and the part number
I have had a look at a store here in oz and this is what i have found can you just check to make sure i have this right
.47uf 100Vdc
http://australia.rs-online.com/web/p/pl ... m/4762825/
2.2k resistor 500vdc
http://australia.rs-online.com/web/p/th ... d/0386240/
2200pf 500vdc
http://australia.rs-online.com/web/p/mica/0495896/
Author:  gvzookdriver [ Mon Jun 18, 2012 10:49 pm ]
i have just found this other page with the part number and it gives the tolerance for each item. I will need to change the above items because of the tolerance
http://www.ecwant.com/p_1151331_noise-s ... 2-1105.htm
Author:  Rhinoman [ Mon Jun 18, 2012 11:21 pm ]
You're OK on the tolerances as the stock items aren't so accurate, I wold go for a metal film resistor for reliability and you need a higher voltage rating anyway.
Author:  royce [ Tue Jun 19, 2012 6:51 am ]
Have you checked with suzuki if the part is still available?
Author:  gvzookdriver [ Tue Jun 19, 2012 7:18 am ]
Yeah it is still available they have said it will be a special order and will take a minimum of a month to get here. have ordered one but It's the only thing left to do to start the car then get rego before I move back to Brisbane.
Author:  JrZook [ Tue Jun 19, 2012 9:52 am ]
gvzookdriver wrote:
have ordered one
How much they worth these days?
Page 1 of 2 All times are UTC + 9:30 hours
