| body lift in a 1 ltr ute https://auszookers.com/forum/viewtopic.php?f=5&t=33476 |
| Author: | jimbo_jones [ Sun Jun 17, 2012 4:23 pm ] |
| Post subject: | body lift in a 1 ltr ute |
my mate bought a 2" body lift from fat zook with the blocks in he cant get 2nd 4th or revers gear as it seems to be fouling on the body has any one done a body lift in one of there before? Dose the shifter need to be heated and bent? the zook is a lwb hard top ute 1982 with all std running gear we were under the impression the kit was a straight bolt in kit my body lift I put in my lwb 86 soft top bolted straight up never had any problems with the shifter |
| Author: | want33s [ Sun Jun 17, 2012 5:23 pm ] |
| Post subject: | Re: body lift in a 1 ltr ute |
The kit is a bolt in fit... It bolted in didn't it? Most Sierras need the front and back of the gearshift hole in the floor enlarged by 5mm or so. |
| Author: | christover1 [ Sun Jun 17, 2012 6:33 pm ] |
My 1.0 LWB needed the transfer and gearstick holes made a bit larger, to stop foulings, after my home made body lift |
| Author: | just_cruizin [ Sun Jun 17, 2012 7:23 pm ] |
Try it without the boot, if it gets all the gears Trim the steel ring around the boot, this should let it flex enough to get all the gears. All body/chassis are different and the way interact too. The make of the kit wont change this, it's just a body lift thing. Did he send Pete a message or call him before you posted this up. Here's a good hint to everyone who buys something that doesn't fit straight up, call the supplier we're happy to help out. |
| Author: | Fatzook [ Sun Jun 17, 2012 9:09 pm ] |
I did speak to Jimbo today, but not regarding this. Given that this is such a common issue with ALL body lifts, not just for sierras, and that there is no way to solve it with 'bolt in' parts, I just assumed that people would deal with this issue, should it occur. I will ammend my fitting instructions to outline this potential issue. Unfortunately there is nothing that I can do as a seller to correct it though. |
| Author: | jimbo_jones [ Mon Jun 18, 2012 11:58 am ] |
this wasnt a issue for pete to worry about as its not the fault of the kit just seeing what others have done to corect the problem with the shifter |
| Author: | just_cruizin [ Mon Jun 18, 2012 12:10 pm ] |
It's damn Suzuki and every fitment being different |
| Author: | Fatzook [ Mon Jun 18, 2012 12:55 pm ] |
just_cruizin wrote: It's damn Suzuki and every fitment being different x2 |
| Author: | jimbo_jones [ Mon Jun 18, 2012 5:19 pm ] |
we finished fitting it today, Pete the kit you sent looks to be a 1.3 swb with a few extra block added we made up some extra rubber pads to take up the space where the female bolts ouldnt screw up all the way my mate didnt want to mod the kit. and the instructions sent with the kit also said it was to suit a swb?? as for the shifter we bent itin a "S" to suit with the oxy so it clears the floor and dosent hit the dash when in first seems to work ok. |
| Author: | Fatzook [ Mon Jun 18, 2012 5:35 pm ] |
jimbo_jones wrote: we finished fitting it today, Pete the kit you sent looks to be a 1.3 swb with a few extra block added we made up some extra rubber pads to take up the space where the female bolts ouldnt screw up all the way my mate didnt want to mod the kit. and the instructions sent with the kit also said it was to suit a swb?? as for the shifter we bent itin a "S" to suit with the oxy so it clears the floor and dosent hit the dash when in first seems to work ok. Yeah instructions are the same. The female bolts you recieved are a fair bit shorter than the 1.3L bolts. |
| Author: | jimbo_jones [ Mon Jun 18, 2012 6:10 pm ] |
Fatzook wrote: jimbo_jones wrote: we finished fitting it today, Pete the kit you sent looks to be a 1.3 swb with a few extra block added we made up some extra rubber pads to take up the space where the female bolts ouldnt screw up all the way my mate didnt want to mod the kit. and the instructions sent with the kit also said it was to suit a swb?? as for the shifter we bent itin a "S" to suit with the oxy so it clears the floor and dosent hit the dash when in first seems to work ok. Yeah instructions are the same. The female bolts you recieved are a fair bit shorter than the 1.3L bolts. when comparing to the kit in my zook the bush on the outer side of the chassie is the same as mine |
| Author: | just_cruizin [ Mon Jun 18, 2012 6:43 pm ] |
Is it a 1.0lt body on a 1.3 chassis? |
| Author: | Fatzook [ Mon Jun 18, 2012 6:44 pm ] |
just_cruizin wrote: Is it a 1.0lt body on a 1.3 chassis? both 1L |
| Author: | jimbo_jones [ Mon Jun 18, 2012 7:07 pm ] |
I wrote that last post wrong ment to say when comparing to the kit in my zook the gap for the bush on the outer side of the chassie(1 ltr) is the same as mine (1.3) |
