Joined: Sat May 21, 2011 9:35 pm Posts: 63 Location: mackay
Posted: Sun Jun 17, 2012 8:11 pm
i have managed to scrape together all the parts to instal air con on my j20 vit. i scored a brand new wiring loom that plugged straight in but i have one wire left that i cant work out where it goes. its a yellow wire with blue trace. its a single wire that comes from the loom that plugs into the 2 relays in front of the fuse box. it has a black cover over it and heads from under those relays towards the firewall. think it then heads left towards the back of the motor but i dont know where it plugs into. can anyone help me out here. just a pic of the engine bay would be a help. i need to see the rear of the engine from fairly high up.
i also have a spare plug under the dash but im hoping it will work without this loom being plugged into anything. once i get it gassed up hopefully ill be able to work out the under dash stuff.
Some a/c setups have a coolant sensor to detect an "overheat" condition - if the temp exceeds a given value, they disable the compressor (to decrease the heat load) and enable the condenser fan (to increase air flow) - this might be that wire heading toward the back of the motor.
The older Vitaras (SE416) worked this way - newer Vitaras (SQ series) don't have the additional sensor, the ECU performs the required function, unfortunately I haven't worked with yours (SV series) so I don't know.
Posted: Tue Jun 19, 2012 7:53 pm
hmmm thanx fordem. it may well do that, however i cant find anything for it to plug into. hoping for someone with a similiar vehicle will know. im starting to think i should just give up on this air con. the parts are impossible to get and info on this model is scarce as hens teeth!!
It's entirely possible that you don't have the extra temp sensor fitted - if that's what it is, the a/c should function with it disconnected, you could also try grounded it through a small lamp bulb (a park lamp bulb) and see if it disables the compressor clutch.
Posted: Fri Jun 22, 2012 8:02 pm
thanx heaps gus. as usual a very comprehensive answer. dunno if i have that little sensor in the back of the head, ill have a look when i bring the car home from work.
on a side note i just bought a condensor off ebay and of course it looks like it will fit, but the fittings are different. for anyone one considering puting air con on a non air con j20 vit, dont do it. its to hard!!
Users browsing this forum: Google [Bot] and 64 guests
