It is currently Thu Nov 12, 2026 12:07 pm
Vehicle: 1.6 SJ80
Post Posted: Tue Jun 19, 2012 5:17 pm
Hi guys, I'm running a g16b in my sierra with g13b sump. I need to replace the sump gasket, do I order the g13b one or g16b?
Vehicle: Yellow Ute
Post Posted: Tue Jun 19, 2012 5:35 pm
Niether, just use gasket goo. Most of them are anyway.
Post Posted: Tue Jun 19, 2012 6:23 pm
1.3 or 1.6 gasket are same.
Post Posted: Tue Jun 19, 2012 6:29 pm
X2 when I last tried to source one the guy just grabbed some gasket sealant goo. Working fine so far.
SS
Vehicle: 1.6 SJ80
Post Posted: Tue Jun 19, 2012 7:04 pm
Thanks want33s.
Post Posted: Wed Jun 20, 2012 6:17 am
Suzuki G series engines don't have sump gaskets, they use Liquid Sealant from Factory. But you're right in that the bolt pattern is identical (otherwise you wouldn't be able to swap sumps), so if an aftermarket gasket kit includes a sump gasket, then either a 1.3 or 1.6 will fit.
Users browsing this forum: Google Adsense [Bot] and 65 guests
