It is currently Sat Nov 07, 2026 3:03 am
Vehicle: 08 jimny, 3"JB. xrox
Post Posted: Sun Jun 24, 2012 3:17 pm
I have a Jimny with a 3" jimny bits lift installed and it is leaning on the drivers side. Does anyone else have the same problem? I emailed JB and they sent me out a new front drivers side spring but it dosent seem to have fixed the problem.
3" JB, 215 Hankook dynapro, Xrox.
Post Posted: Sun Jun 24, 2012 3:41 pm
prolly similar to sierra where theres more weight on the drivers side so it leans a little.... did you check both front and rear springs are on the correct left and right sides? Some manufacturers put a stiffer spring on the drivers side front and rear to counter it.
Post Posted: Sun Jun 24, 2012 3:49 pm
i have no dramas with my JB lift. you put the longest spring in the kit front/drivers side?
should be:
LONGEST : Drivers Side front
2nd: Passenger Front
3rd and 4th (shortest ones) : Back.
MY BUILD THREAD HERE!!!!!
Vehicle: 03 Jimny
Post Posted: Sun Jun 24, 2012 5:25 pm
I had the same problem, did the way scales has it and still had the lean, spent hours swapping springs around and had no luck.
I now run 75mm in the front front and 40mm coils in the rear, no more lean but sits 10mm higher in the fronт and I've got better articulation
Post Posted: Sun Jun 24, 2012 9:44 pm
My 50mm Kings have a longer spring in the front right. It seemd ok for a while, but seems to lean again. It is VERY soft.
With the weight of the cage, bar and winch, its only 5mm higher than standard in the front! I am on the lookout for a stiffer set.
Post Posted: Mon Jun 25, 2012 4:17 pm
Yeh longest is front drivers side. Was wondering if it made a difference with the standard springs having the longer one in the rear drivers side. Was thinking about trying a 15mm spacer in the rear drivers side?
Vehicle: 03 Jimny
Post Posted: Mon Jun 25, 2012 6:03 pm
Is your lean about 30mm difference?
Post Posted: Mon Jun 25, 2012 6:21 pm
No its only 10-15 mm when parked but mor noticeable when driving. Leans more on left turns than right and on side slopes.
Vehicle: 03 Jimny
Post Posted: Mon Jun 25, 2012 6:29 pm
Yep exactly how mine was
Post Posted: Mon Jun 25, 2012 7:01 pm
Just wondering how you are running 40mm coils in rear? Are they the front springs off 40mm lift run in the rear?
Vehicle: 03 Jimny
Post Posted: Mon Jun 25, 2012 7:27 pm
I started to swap the Jimny coils around but couldn't get my lean to go away, I mix the coils around until i got it right. Either they are 40 or 50mm coils that are the same size so they are,rear springs in the rear.
I've put a short 75mm coil in the passenger and a long one in drivers side, has a slight lean to passegnger side when parked but when I get in it sits level.
Users browsing this forum: No registered users and 375 guests
