It is currently Sat Nov 07, 2026 1:31 am
Post Posted: Sun Jul 01, 2012 7:15 am
Just looking at my young fellas vitara yesterday and seriously wondering if it will take 31,s after we fit 3" lift? Looks to me like some major panel beating in wheel arch will be needed. Any experience guys in what size will go on without to much hassle?
Post Posted: Sun Jul 01, 2012 9:50 am
Lift alone does not allow tyres any larger than standard to be used.
You need bumpstop extensions and or guard cutting/reshaping.
Post Posted: Sun Jul 01, 2012 9:52 am
30's will fit with minimal fuss.
31's will clear with some small modifications to the rear edge of the front wheel arch and the rear edge of the front bumper.
In a SWB, they should clear in the rear OK, but bumpstop spacing will help if they are catching the top of the rear wheel arch.
Suspension lift doesn't fit bigger tyres. Bumpstop spacing, body lift and guard work fit bigger tyres.
Post Posted: Sun Jul 01, 2012 10:11 am
While this is kind of true, there are still plenty of people running around with 3" lifted Vitara's & 30-31" tyres so they must fit somehow. :wink:
Post Posted: Sun Jul 01, 2012 10:33 am
Absolutely. The fit irrespective of suspension lift, with minor guard work.
Post Posted: Sun Jul 01, 2012 11:10 am
I am running 31" extremes which are a smidge bigger than 31".
I am running a calmini 3" kit in swb and all that was required was a bit of a message on the backside of the Front wheel arches and adjust the steering stops a bucket load. I am running a ARB front bar so there is lots of clearance on that side. In the rear with -13 rims the tyres JUST tuck under the guards.
Post Posted: Sun Jul 01, 2012 5:15 pm
Thanks guys, will have custom bullbar so no worries about clearance on front side of front tyres, I own a grinder and lump hammer so massaging shouldn't be a drama just the bumpstops... Guess I will just ask whichever shop fits them to sort it out.
Post Posted: Sun Jul 01, 2012 8:34 pm
Yeah, the suspension doesn't work. Because the springs are that high, they need to be ultra stiff and don't flex. But hey, it that's what you're going for it'll work. By the way, stock up on CV's
Post Posted: Sun Jul 01, 2012 8:55 pm
yeah 3" springs don't flex. :roll: fair enough it's got one of your body lifts in it & 31's but you can't say that it doesn't have a pretty balanced amount of flex front & back.
dead stock sierra for reference. :thefinger:
Post Posted: Sun Jul 01, 2012 9:41 pm
Ok, I sit corrected :oops:
However most Vit drivers don't put the effort and research into the setup that you have.
Most 'kits' out of the box use a stiff spring to try and retain height rather then attain a setup that works, which yours obviously does well.
Post Posted: Sun Jul 01, 2012 9:43 pm
stock leaf sierra is a pretty unfair comparasion too. :wink:
Post Posted: Sun Jul 01, 2012 11:00 pm
hahah, it was the only other pic with the car in the same spot.... sway bar & all. :lol: :oops:
Post Posted: Mon Jul 02, 2012 4:15 am
Vits dont flex at all
Post Posted: Mon Jul 02, 2012 5:47 am
doesn't matter if vits flex, as they are only any good if they are donating there bits to a sierra
Post Posted: Mon Jul 02, 2012 7:17 am
That's where calmini stand above the rest. All other lifted springs I've seen are Just thicker steel coils and slightly taller. Rough as guts.
The calmini rears are Monster springs! They are small diameter coil and long length. Even the front coils on my Vit will happily fully extend, compress over Rutted sections.
Post Posted: Mon Jul 02, 2012 10:13 am
But the calmini ones r to soft and cant take the weight of much camping gear
Post Posted: Mon Jul 02, 2012 10:17 am
Part of the reason why I use Nissan 180 coils, tall free standing height, soft.... Gives good height with good flex.
Post Posted: Mon Jul 02, 2012 10:54 am
this is true, but i don't think they had touring on their mind when designing the the kit & i'm pretty sure it was developed on the SWB's
Post Posted: Mon Jul 02, 2012 11:01 am
Do they have different springs for lwb
Post Posted: Mon Jul 02, 2012 11:10 am
not that i know of, i wonder how well the 2.5 GV rear springs would work? i run the GV calmini fronts in mine cause of the extra weight of the motor.
hang on, don't GV's have a slightly different top rear spring mount?? :?
Post Posted: Tue Jul 03, 2012 5:22 pm
I think they do
Post Posted: Fri Jul 06, 2012 7:52 pm
I ran Tough Dog GV springs in the back of mine for ages (in fact they're still in there...)
Fit perfectly, but a bit too firm for my liking. For reference the Cal springs were nice in a completely empty LWB, but useless as soon as there was any load in the car.
35mm Tough Dog GV lift matches 3" Calamari Vit lift perfectly, so the Cal GV stuff might be close...
Vehicle: 96 LWB Vit, 2.5L powerhouse
Post Posted: Fri Jul 06, 2012 8:06 pm
Can i just chuck this in there, i have a lwb vit and will be aiming eventually for around the 3 inch lift mark. But in the meantime i will be running the 40mm lift with spring spacers. I want to find the skinniest tyre i can and am thinking around the 30inch mark. It will be on 16inch rim and was wondering if anyone has found anyting similair? A 30 x 9.5 is skinny in a 15 and i think 225/75/16 is as close as u can get to that??? Thanks.
1997 Sierra, daily driver, 60mm coils, 2 inch body
Users browsing this forum: Google [Bot] and 131 guests
