It is currently Sat Nov 07, 2026 1:32 am
Post Posted: Sun Jul 01, 2012 9:52 am
Hi there.
A couple of questions :
1. Has anyone ever swapped a Hilux IFS Front and rear diff under a Vitara Before.
2. What gearing options are available for the setup.
3. Would it be a worth while setup.
Stocker
Post Posted: Sun Jul 01, 2012 9:59 am
Plenty of vitaras have had hilux rear diffs fitted.
Front diff? Maybe. It would be VERY hard to fit between the sump and the crossmember though - they are much bigger. It would be a major fabrication exercise. I'm also suspicious they might be wider flange to flange, so there isn't any more room for axles to add wheel travel. IFS hiluxes have less than no wheel travel.
I think the lowest ratio for a hilux is 5.7something, but I heard these had a very weak pinion. It seems the lost commonly available ratio now is 5.29. Not much of an upgrade over 5.12.
Post Posted: Sun Jul 01, 2012 10:01 am
http://bbs.zuwharrie.com/content?topic=100330.0
http://www.pirate4x4.com/forum/showthread.php?t=318480
Might be easier than I thought, but still quite a bit of work.
Post Posted: Sun Jul 01, 2012 10:13 am
Thanks Steve! I'll keep looking into it then :)
Stocker
Users browsing this forum: Google [Bot] and 129 guests
