It is currently Sat Nov 07, 2026 1:32 am
Post Posted: Tue Jul 03, 2012 7:53 pm
Driving around today, started hearing a slight grinding noise and Bang???????
Got home and found this on the front drivers side 8O
Check out the stub axle.........calling Boggomobile.........do you have one?
It was real dirty in there so I suspect mud & water is the culprit.
Phuck Photobucket
Post Posted: Tue Jul 03, 2012 8:06 pm
a slight grinding noise.... are you deaf? 8O :lol:
pm wants33 for a spare
Vehicle: 03 Jimny
Post Posted: Tue Jul 03, 2012 8:21 pm
Have done this twice. You must be deaf :lol: it doesn't sound good at all.
Post Posted: Tue Jul 03, 2012 8:26 pm
Give me a break........stereo was cranked
Phuck Photobucket
Post Posted: Tue Jul 03, 2012 8:33 pm
Well done!
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Tue Jul 03, 2012 8:34 pm
but seriosly I thought it was mud in the front brakes after the run last weekend. It was just a slight tinny noise and not all the time? Havent driven it around too much till today and thought "I'll check that when I get home".
Cheers atari I'll contact Wants33 if Boggomobile hasn't got one :wink:
Phuck Photobucket
Post Posted: Wed Jul 04, 2012 8:55 am
thats what my last one did. Unlucky mate.
93 sierra 2"spring2"body 31,s & 4.9s
Post Posted: Wed Jul 04, 2012 9:06 am
Awesome tech.
How not to look after wheel bearings and result.
Post Posted: Wed Jul 04, 2012 10:33 am
I still honestly don't know how you guys don't notice/feel/hear your bearings before they fully collapse like that!
Lil Foot!
Post Posted: Wed Jul 04, 2012 11:58 am
She'll be right, wack it back in with some more grease...
Post Posted: Wed Jul 04, 2012 12:07 pm
I've re-built a few diffs that had nuggets like this.
Its so easy to check for play in wheel bearings. Every time you change your oil, jack the car up, grab the tyre at 12 o'clock and 6 o'clock, and wobble it. If there is movement, check your bearings.
Post Posted: Wed Jul 04, 2012 1:18 pm
The problem is, some dont last an oil change, especially in shitty muddy states.... :|
Post Posted: Wed Jul 04, 2012 2:42 pm
If your bearings aren't lasting 10,000kms you have some serious issues!
Post Posted: Wed Jul 04, 2012 2:59 pm
I have a heap of spindles here.
Post Posted: Wed Jul 04, 2012 9:54 pm
Got one today from Boggomobile so all good.
Something interesting I found today, pulled the other side apart this arv, not that anything seemed out of place here, and found that both seals, the one behind the bearing and the axle seal were both failing?? Will post some pics tomorrow.
Now remembering it was only a little over a month ago these were replaced new on both sides. I purchased the bearing/seal kit off ebay and yes it was one of the cheaper ones (can all ready hear the "told you so" :roll: )
Phuck Photobucket
Vehicle: 03 Jimny
Post Posted: Wed Jul 04, 2012 10:09 pm
Might be a dump thing to ask but you did remember to pack the bearings
Post Posted: Wed Jul 04, 2012 10:11 pm
Post Posted: Wed Jul 04, 2012 10:18 pm
ben i get my bearings from coastline bearings my old man has used them for ages nice guys very helpful
Post Posted: Wed Jul 04, 2012 10:19 pm
my front wheel bearings have lasted longer then i have been a member of AZ.
Post Posted: Wed Jul 04, 2012 10:28 pm
thats because there non flammable haha
Post Posted: Wed Jul 04, 2012 10:32 pm
no knob gobbler it is because i fit them properly, i bet you lot use a chisel and hammer to do the bearing nuts up.
Post Posted: Wed Jul 04, 2012 11:07 pm
no knob gobbler it is because i fit them properly, i bet you lot use a rock to do the bearing nuts up.
:wink:
Lil Foot!
Post Posted: Wed Jul 04, 2012 11:33 pm
:rofl: @ nob gobbler
Post Posted: Thu Jul 05, 2012 12:16 am
are you following the manual where its says to do them up motheruckingcrazy tight, back them off then do them up to 'snug' ? since mine were done like that i've not had an issue at all... when they were just "done up" they only lasted around 5-7,000km.
Post Posted: Thu Jul 05, 2012 7:24 am
or (from memory) 50flb - 0flb - 10 flb
Post Posted: Thu Jul 05, 2012 8:29 am
^^ yeah that.
Post Posted: Thu Jul 05, 2012 8:33 am
Make sure the spindle surface, where the seal runs, is clean and smooth too. A rough, corroded surface will quickly chew out a seal
Post Posted: Thu Jul 05, 2012 8:43 am
I do my as per gwagens suggestions first nut to 90flb then to 0flb the to 15flb second nut (outer) to 80flb.
I now check then after every mud trip. Spindles are good condition too. Sometimes they will last, sometimes they won't, depends on what terrain I have been driving.
Vehicle: Yellow Ute
Post Posted: Thu Jul 05, 2012 8:55 am
The FSM says first nut up to 90flb spinning the hub, back to 0flb, then 15flb. Lock washer on. Lock nut up to 80flb
Post Posted: Thu Jul 05, 2012 9:39 am
Haha memery was wrong but that is why I have a FSM in my tool box
Users browsing this forum: No registered users and 127 guests
