It is currently Sat Nov 07, 2026 1:01 am
Vehicle: 85 hightop drover
Post Posted: Wed Jul 04, 2012 2:16 pm
Please, does anyone know the GVM and kerb weight
Of a LWB Sierra trayback is ? So know how much you
Can load one up?
16valve efi hightop drover
Post Posted: Wed Jul 04, 2012 2:35 pm
Can load one up?
400kgs, or therabouts. Its no more than any other sierra. 1370kg rings a bell.
Post Posted: Wed Jul 04, 2012 3:01 pm
Yeah LWB GVM is 50Kg's more than SWB but that 50Kg is the extra weight of the longer wheelbase.
Post Posted: Wed Jul 04, 2012 3:05 pm
Yep. Its all for show. :lol:
I've had 400kgs of cement bags on my ute, and it was well and truely overloaded.
Post Posted: Wed Jul 04, 2012 3:15 pm
Thanks dudes, I was seeing if it was any difference from swb,
Because I want to set one up longer trips, mainly because you
Can fit a good size fuel tank under the tray, and not have jerrys
In the cab like I have to now, good idea?
Post Posted: Wed Jul 04, 2012 3:28 pm
Absolutely.
Post Posted: Wed Jul 04, 2012 3:35 pm
Jackaroo 85L tank in my ute. Comes in carby and EFI models.
Sorry the pics are so shitty.
Vehicle: SJ51T
Post Posted: Wed Jul 04, 2012 4:15 pm
I'm doing the same Drova!
I like fatzooks tank set up but I still want to keep my spare under the tray so i think ill be putting a 70ish L tank in front of the rear axle. I think Gwagen posted a pic of it somewhere.
In case I go down the same path as you pete; does that tank fit under the standard tray mounts?
Matt
Post Posted: Wed Jul 04, 2012 4:22 pm
Very nice, that's plenty of fuel to keep a Zook
Going, fits up nice and High and centered!!
Well when/if I find one that's what I'll do thanks
Am looking at trying to get hold of a drover trayback,
(Sentimental value, got drove around in one as a kid)
But Would imagine there even harder to find??
Post Posted: Wed Jul 04, 2012 4:27 pm
Matt
If you can get me the height of the standard tray mounts I can tell you. I made new mounts, because I had to build the rear of the chassis myself.
Vehicle: SJ51T
Post Posted: Wed Jul 04, 2012 4:33 pm
Matt
Awesome! I'll PM you tomorrow, thanks.
Drova
I think you might be better off just looking for either. Took me a while to find one and it just happened to fall on my lap.
Post Posted: Wed Jul 04, 2012 4:54 pm
Matt
Drova
Sound advice matt, I know I can't be picky! Fingers crossed!!
Post Posted: Wed Jul 04, 2012 5:27 pm
Fatzook, got any dimensions on the Jackaroo tank? I'd like to see if it'l fit in an LJ81. What generation Jackaroo was it from?
What are you after, a resto project or a buy and drive type thing?
I know where one is that has a good cab(well might do, the guy said he was gona flip it upside down to get the wheels off it....) and chassis but would need basically everything else. There's another one there that is well stuffed (extremely rusty).
I'd say in SW W.A Drover tray backs are more common than 1.3l Sierra traybacks, but those are rare as anyway. I'l keep an eye out for you if you want, I come across my fair share of Suzukis. :)
Post Posted: Wed Jul 04, 2012 6:31 pm
Firstly thanks sideways, not really sure set way,
I would do restore project something not runing
With a good cab+chassis, but if something runing
Pops up I'll be keen aswell!
Thanks lot!! Mate, would be excellent if you could
Keep an eye out for me I would very much appreciated!
Luke
Vehicle: Drover pickup turk
Post Posted: Wed Jul 04, 2012 7:34 pm
1390kg :wink:
I like the tuna here
Post Posted: Wed Jul 04, 2012 8:11 pm
1390kg :wink:
20kg :wink: I've taken shits that weigh more than that :thefinger:
Post Posted: Wed Jul 04, 2012 8:49 pm
Hahaha.
Post Posted: Thu Jul 05, 2012 12:55 am
Luke
No worries at all mate, I'l let you know if I find anything that suits! :)
Post Posted: Fri Jul 06, 2012 8:19 am
1390kg :wink:
FYI the tub tray lwb models are too 1390kg.
Mine with 33x12.5, no bar or winch, two blokes, rear bar and swing away, ca18det engine and gearbox was 1380kg :?
Post Posted: Fri Jul 06, 2012 8:46 am
Brenno wrote:
1390kg :wink:
Not much room for gear :wink:
My ute weighed about 980kg with me in it ( alloy tray )
Post Posted: Fri Jul 06, 2012 11:08 am
So pretty much 700kg unladen :)
Lil Foot!
http://tiny.cc/gtsw1
Post Posted: Fri Jul 06, 2012 11:18 am
Careful. You might get snapped in half next time we meet, little man :thefinger:
Vehicle: SJ51T
Post Posted: Fri Jul 06, 2012 4:38 pm
Fatzook
Rear most tray mount is 180 and the next mount is 200mm off the chassis
Post Posted: Fri Jul 06, 2012 4:50 pm
matty_wall wrote:
Fatzook
My rear most mount is 225. But my tray design is very different to yours. To be safe, make sure you have 225mm from top of chassis rail to floor of your tray.
Vehicle: SJ51T
Post Posted: Fri Jul 06, 2012 5:09 pm
matty_wall wrote:
Fatzook
Thats doable. I don't have a tray and was planning on stealing some ideas from your tray. 50x50 rhs as runners will cover the extra height I need. Thanks for the info.
Matt
Post Posted: Sat Jul 07, 2012 7:04 pm
A friend of mine runs a 100L custom made tank in his LWB maruti flat tray. Behind the rear axle still. It's SPOA though, which helps for clearance. He runs his spare hard against the rear of the cab with the tray notched out to allow the wheel to sit down above the rear tailshaft. With a standard hilux split rim and tyre in the hole, it still clears his window for 100% view rearwards.
I run the exact same tank setup as fatzook in my LWB, mine is from a '93 Jackaroo LWB. Mines also a flattray. I currently don't have a spare wheel mount anywhere, but in the future I will build a fold down rear wheel carrier to hang it out the back, as I don't have a 'comp' tray, but built a conventional one. I will eventually upload pics in my build thread when I do.
I had to move tray mounts to fit the tank how I wanted it. I only run 3 tray mounts down either side, but equally spaced them.
I'll upload a pic shortly.
GTi Turbo & A LWB Sierra.
Post Posted: Sat Jul 07, 2012 11:20 pm
They are the brackets I made, plus fitted a water tank under the tray also. The jackaroo tank is a great fit, props to Fatzook for finding it!
Post Posted: Sun Jul 08, 2012 7:52 am
Baleno tank would be an awesome fit under a trayback too.
Bonus is they are dirt cheap and already have EFI pump.
Users browsing this forum: Google [Bot] and 90 guests
