https://auszookers.com/forum/
Swift sedan g16b compared to vitara or baleno g16b
https://auszookers.com/forum/viewtopic.php?f=5&t=33921
Author:  your_mum [ Fri Jul 06, 2012 6:15 pm ]
Post subject:  Swift sedan g16b compared to vitara or baleno g16b
Hi, does anybody know the difference between a swift sedans g16b compared to a baleno or vitara g16b.
From what i understand, it would obviously need to be changed feom east west to north south configuration but im unsure if the cam and dizzy need to be changed like i have heard needs doing to a baleno motor.
According to specs i found on the net, there is .4kw less and 6 nM more in the swift over a baleno donk, so basically identical.
What am i missing?
Author:  appsie [ Fri Jul 06, 2012 7:37 pm ]
Post subject:  Re: Swift sedan g16b compared to vitara or baleno g16b
the swifts are throttle body injected??? and a bit more of a shit fight to get running right i believe. and needs dizzy adaptors etc?? or different cam?
Author:  your_mum [ Fri Jul 06, 2012 9:27 pm ]
Yeah its a tbi 16v, and the dizzy points out the back of the motor. What would i need to change to get the dizzy pointing in the right direction?
Author:  christover1 [ Fri Jul 06, 2012 11:07 pm ]
A cam change to a Vit cam should be what ya need.
I fitted a Baleno/swift import G16B dizzy motor to my Vitara.
I used the Vitaras cam and dizzy.
I assume same if fitting to a Sierra.
Plenty of dead vit engines around to grab a cam from, I reckon
Author:  BlueSuzy [ Sat Jul 07, 2012 1:44 am ]
Otherwise get a baleno 98+ motor.
G16b, Twin coilpacks.
No dizzy. Sump has to be modded for sensor or find a rare grandvit 2door 1.6 sump, or whole motor!
Water has to be custom/modded also, come out back of head.
Is this for the memphis?(just cut the firewall)
Author:  your_mum [ Sat Jul 07, 2012 5:52 am ]
Thanks guys.
Tim- its an engine that I bought with the intention of selling, or possibly putting in Memphis and selling the complete turn key vitara g16b efi thats in it.
I'm thinking of putting a little turbo on for shits and giggles, if so ill cut the firewall out and have in cab adjustable timing ;)
Author:  appsie [ Sat Jul 07, 2012 7:59 am ]
while we are on this timmay. i have a complete running low km g16b 2000 model coil pack baleno here that i will be putting the motor in the buggy unless a super cheap g16a comes up. What have you done in the past with the outlet out the back of the motor?? at a guess it willl put the rad hose into the firewall?? i know a stainless pipe will need to be made to run up the side of the motor
Author:  BlueSuzy [ Sat Jul 07, 2012 11:54 am ]
your_mum wrote:
Thanks guys.
:lol:
Author:  Gwagensteve [ Sat Jul 07, 2012 12:56 pm ]
I have photos of how I did Michael's in the trolley tug build thread.
viewtopic.php?f=4&t=14025
