https://auszookers.com/forum/
Vitara: Are all Tie rods & drag links same across the range?
https://auszookers.com/forum/viewtopic.php?f=5&t=33936
Author:  christover1 [ Sat Jul 07, 2012 4:04 pm ]
Post subject:  Vitara: Are all Tie rods & drag links same across the range?
Some tie rod and kit sellers claim " only suit LWB or SWB or years etc."
I would assume all were same,
but I could be wrong.
Not found any differences in drag link types, but worth asking the oracles
Author:  FullyZooked [ Mon Jul 09, 2012 7:39 am ]
Post subject:  Re: Vitara: Are all Tie rods & drag links same across the ra
There are differences but I have only found them to be for the standard Vitara and the "sport" which has slight bends near the end of the draglink. I would say for clearance.
Author:  christover1 [ Mon Jul 09, 2012 8:50 am ]
Thanks.
WWill keep that in mind, too.
My drag link is straight, and my tie rods look same as what is pictured on ebay.
No hurry yet,
but a dicky tie rod boot means it will need a replacement at some time.
I could cheap out and buy just the one tie rod,
but total replacement of all sounds wise on a 19 year old car.
Author:  christover1 [ Mon Jul 09, 2012 10:34 am ]
These look like mine.
Very cheap, which is good and also a worry.
Located in Aus which is good and unusual.
Don't include a drag link.
http://www.ebay.com.au/itm/4-TIE-ROD-EN ... 27b4f26960
Author:  lee88 [ Mon Jul 09, 2012 1:56 pm ]
I bought from that supplier the whole set up including the drag link & tie rods.
The actual parcel was sent from Taiwan(? - only from memory but it was from one of those countries lol)
I had problems with the drag link etc sitting too close to my diff - getting diff drops fixed my problem & left enough room so they didn't hit anymore. (i think the end bits are a bit fatter then the stock ones - not the actual bolts they are fine i mean the size of the actual joint)
Quality wise - mine have been ok. i haven't had any problems yet but i do have a small split in one of the boots (maybe i did it up too tight?)
(But note my car only really gets used for 4x4ing.)
i couldn't notice any size differences when i put them next to my stock ones only that the joint is a bit fatter at the end
hope this helps
Author:  christover1 [ Mon Jul 09, 2012 2:45 pm ]
hope this helps
Thanks, much appreciated.
Already have a diff drop, and seems to be plenty of room, so that should be fine.
No hurry, yet, too much else is on the to do list first. :)
Author:  Gwagensteve [ Mon Jul 09, 2012 2:51 pm ]
Are you looking for an upgrade or just an equal replacement? I have at least two sets of vitara tie rods/drag links here that would be going down the tip.
IMHO a 2.0 vitara might have a different drag link due to the wider chassis (?) but the tie rods should be the same as the wishbones are the same length.
Author:  christover1 [ Mon Jul 09, 2012 3:01 pm ]
I just have one torn boot, been that way a while.
Happy to grab the tierods and drag links off you.
Can't hurt to have spares.
I can come up anytime, or if you can bring to meeting be nice?
Author:  Gwagensteve [ Mon Jul 09, 2012 3:27 pm ]
I won't have time to sort it out before the meeting - I have to split rods off of steering boxes / out of cars etc. They are here though if you need them.
