It is currently Sat Nov 07, 2026 1:32 am
Post Posted: Mon Jul 09, 2012 6:02 pm
Picking up a second hand set of calmini 3" raised springs, They have more then likely sagged so I'm not sure if I should get them reset or not. What length shocks will I need to run if I get them reset and will I need to run a droped pitman arm and bump stop extensions? If I don't worry about getting them reset will I be wright if I just get some shocks to suit 2" raised springs?
Vehicle: 2018 DMAX
Post Posted: Mon Jul 09, 2012 7:02 pm
You would be best of measuring up for shocks after fitting the springs, very hard to tell the correct length otherwise.
The 3" Calmini from what I have read use a pretty heavy spring rate, if there worn in now they will probably be perfect to chuck straight in.
Stock pitman arm will be fine, and bump spacers will depend on the tires you use.
Post Posted: Mon Jul 09, 2012 7:46 pm
Ok I'm only running 235/75/15 so I guess I'll be right with my standard bump stops
Users browsing this forum: Google [Bot] and 134 guests
