It is currently Sat Oct 10, 2026 10:02 am
Post Posted: Thu Jul 12, 2012 2:44 pm
Hi all.
Been trying to find a sierra to do a ground up restore/build on. Managed to find a hard top for a great price.
Problem is we really want a soft top.
How hard would it be to cut the roof off the hardtop? Obviously I will add in a rollover bar and things like that.
Also is it legal?
I did search but couldn't find anything.
Thanks
Vehicle: MG410 Gypsy
Post Posted: Thu Jul 12, 2012 2:53 pm
have u purchased the tin top already?
Post Posted: Thu Jul 12, 2012 2:56 pm
Dont even consider it,way too hard to do properly, would cost more than buying a soft top tub and converting it
Post Posted: Thu Jul 12, 2012 2:59 pm
X388,476,723!!!! There's not enough strength in a hard top body once you cut half of it off. And hard tops are too hard to come by anyway
Post Posted: Thu Jul 12, 2012 3:04 pm
that was going to be my next point. haha
just keep looking around. You are bound to come accross a nice soft top in ur price range. ebay always has a few on the go.
Post Posted: Thu Jul 12, 2012 3:17 pm
Do a search on "Islandvitara" .
Vehicle: 1985 Holden Drover
Post Posted: Thu Jul 12, 2012 3:23 pm
Im sure there would be enough people who would pay enough money for the hardtop for you to get a soft top anyway ;)
1989 WT Sierra.
Vehicle: suzuki vitara 1991 jlx
Post Posted: Thu Jul 12, 2012 6:55 pm
hey fellas, on the topic i have a sierra soft top and would love to convert it to a tin top. is this possible? pros and cons?
Post Posted: Thu Jul 12, 2012 6:59 pm
= ignore sound advice & end up with a ruined unfinished project
Post Posted: Thu Jul 12, 2012 7:21 pm
Could just buy it and swap the entire body
Post Posted: Thu Jul 12, 2012 7:50 pm
Chopping down a hard top is one of the Suzuki sins, it's like putting a 3.8 or 4k motor in, building a SWB ute or putting Sierra diffs under an LJ.
In short, if you cut the roof off that hard top, we will find you and we will kill you.
Post Posted: Fri Jul 13, 2012 8:41 am
Haha fair enough. Thanks for the help guys. The search continues :)
Vehicle: 1985 lwb sierra UTE
Post Posted: Fri Jul 13, 2012 9:21 am
But iv always wanted :rofl: :rofl: a 3.8 but iv always wanted to burn a Coily so I guess I'm square LOL.
Green? greeeen is nice !
Vehicle: ***
Post Posted: Fri Jul 13, 2012 10:37 am
Check gumtree for someone wrecking one.
Just buy the body off them. and put that on it. :)
Post Posted: Fri Jul 13, 2012 4:43 pm
You guys should swap bodies!!!! :idea:
Clearance Hole Technology :P
Post Posted: Sun Jul 15, 2012 8:09 pm
X2
Vehicle: suzuki sierra
Post Posted: Sun Apr 03, 2016 1:14 am
hello just bought a suzuki sierra 1987, I want to convert it to a convertible complete with a roll cage and canvas top...am new to the forum any advice or dos and donts?
Post Posted: Sun Apr 03, 2016 3:52 am
Welcome to the forum :D
Post Posted: Sun Apr 03, 2016 8:09 am
Don't.
Post Posted: Sun Apr 03, 2016 8:47 am
^That's the short answer.
The long answer is anything is possible, but you'd have to have a VERY good reason, and be quite skilled, to cut up a hard to top to make something suzuki already built.
How much experience with fabrication, roll cage construction, and part design do you have?
Do you want the completed car to be legal for road use?
What is your intended use?
The hardtop body looses all its strength once the roof is cut off. You need to add sufficient bracing to make the body rigid once the cutting has been done. this means you have to be able to fabricate and weld at a reasonably high level.
The windscreen frame is much weaker in the hardtop and will need some form of support. Also consider that a light roll or flop will damage the now weakened windscreen frame.
Here is a car that was been (successfully) cut into a soft top. The owner did it because the hardtop body was damaged from multiple rolls, and there was lots of work in the wheel arches, transmission tunnel etc, so swapping to a soft top body was more work than the chop. It's very well executed but it's an offroad only car, and would not be legal for road use without engineering approval as the seat belt mounts and roll cage intrusion would be issues. This car also has no provision for weather protection.
Note that both sides of the windscreen are protected.
Post Posted: Sun Apr 03, 2016 9:06 pm
thanks joe. gwansteve some mechanic just shared his thoughts on the same and it boils down to 'bad idea'...problem is I want it soo bad am all over the interner looking up for success stories in regard to converting a suzuki sierra into a sporty ride:-(
Post Posted: Sun Apr 03, 2016 9:18 pm
Buy a soft top they're common enough. It's pointless to go through the cost and time of conversion to end up with something likely inferior to what Suzuki already made.
Vehicle: 86 GTI powered drover,96 coily
Post Posted: Tue Apr 05, 2016 7:15 pm
would probably cost you somewhere in the region of $5k-$10k to do it even remotely properly...... its not like you can just lob the top off a tin top and stitch a canvas top back on...
Vehicle: 1992 suzuki sierra hardtop
Post Posted: Sun Sep 17, 2017 7:55 pm
Sell tintop and by soft top
Post Posted: Sun Sep 17, 2017 8:17 pm
Good advice
Bye
Users browsing this forum: No registered users and 253 guests
