https://auszookers.com/forum/
Locking the viscous hub
https://auszookers.com/forum/viewtopic.php?f=5&t=34387
Author:  reeceh [ Sun Jul 22, 2012 1:32 pm ]
Post subject:  Locking the viscous hub
How does one go about permanently locking the viscous hub fan in a vitara. This is only a temp fix to see if my temperature will drop.
Author:  Rossco [ Sun Jul 22, 2012 1:42 pm ]
Post subject:  Re: Locking the viscous hub
From what I've read the g16b is supposed to run about 100c?
Author:  atari4x4 [ Sun Jul 22, 2012 1:47 pm ]
viewtopic.php?f=17&t=28644&hilit=clutch+oil
lock it up by drilling a couple holes through it & bolt it solid.
Author:  JrZook [ Sun Jul 22, 2012 7:42 pm ]
What temp thermostat do you have in it and how old is it?
Author:  reeceh [ Sun Jul 22, 2012 7:56 pm ]
I pulled the old thermo out as it was totally rooted. I was seeing if it would run cool without it.
Author:  JrZook [ Sun Jul 22, 2012 8:02 pm ]
Get a proper thermostat in it before jumping to overheating conclusions.
Author:  reeceh [ Sun Jul 22, 2012 8:07 pm ]
Just run the recommended tridon one?
Author:  sando [ Sun Jul 22, 2012 8:18 pm ]
Yeah mate!
Also how old is your coolant, if you have access to a refractometer or some test strips you can check if that could be your issue.
Author:  reeceh [ Sun Jul 22, 2012 8:29 pm ]
Did a system clean and flush yesterday. Test strips??
Author:  sando [ Sun Jul 22, 2012 8:40 pm ]
http://www.baldwinfilter.com/productsco ... strip.html
Author:  matfan [ Mon Jul 23, 2012 9:03 am ]
Pretty sure I've got a spare viscous hub fan if you want it
Author:  reeceh [ Mon Jul 23, 2012 10:30 am ]
Thanks but I think I've got bigger problems. The locked hub didn't do bugger all. Have a mate that gets back Thursday that's going to run some tests. Otherwise sando offered to do some tests but he's at Ipswich, don't really want to drive that far.
I've been looking at a few options.
Low km jap import compression tested engine for $1450 3 month warranty
High km engine from a engine dismantler for $1100 3 month warranty
Fully recoed exchange from suzisport for $2200
Not sure if I'll bother to rebuild mine. Not sure on the cost factor. Will def get it crack tested before hand. If its salvageable I might get it rebuilt and either sell or keep sealed up.
Author:  matfan [ Mon Jul 23, 2012 10:33 am ]
No worries, I've got a comp tester if you wanna check it out.
Author:  reeceh [ Mon Jul 23, 2012 10:34 am ]
Yes actually. That would be brilliant!
Author:  matfan [ Mon Jul 23, 2012 10:39 am ]
No worries, I should be home by 5ish, I'll dig it out and bring it up to yours.
Author:  JrZook [ Mon Jul 23, 2012 11:11 am ]
How old is the engine and how bad is it running? I'm finding it very hard to believe you have overheating issues with a locked vit fan and an alloy sierra radiator. I'm assuming you are running a fan shroud and the radiator has been checked professionally and rodded out if there were any issues in that area.
There has to be some sort of issue causing this. What's your timing like?
Author:  reeceh [ Mon Jul 23, 2012 11:45 am ]
The owner of the engine said it had about 160ish thousand Kay's. I haven't taken the radiator in to a shop cause it's brand new. Yes running a shroud. I'll buy a thermostat in the way home.
Author:  reeceh [ Mon Jul 23, 2012 11:46 am ]
I don't have a timing light nor do I have the knowledge in doing timing.
Author:  matfan [ Mon Jul 23, 2012 12:49 pm ]
Got one of those too... the light, not the knowledge :P
Author:  reeceh [ Mon Jul 23, 2012 1:51 pm ]
Thanks. I'll probaly cya this arvo then. Jrzook might be able to help me out about timing. I'll have a crack at this compression test anyway.
