| Vit diff gears into 1.3l diffs? https://auszookers.com/forum/viewtopic.php?f=5&t=34410 |
| Author: | sideways [ Mon Jul 23, 2012 2:05 pm ] |
| Post subject: | Vit diff gears into 1.3l diffs? |
I want to put 4.88 diff gears from a GV front into an SJ50 diff centre. What will I need to do this and how do I do it? Do I need this kit? http://www.lowrangeoffroad.com/index.ph ... -cans.html Thanks Hayden |
| Author: | tanshi [ Mon Jul 23, 2012 2:08 pm ] |
| Post subject: | Re: Vit diff gears into 1.3l diffs? |
you using open centres? if so i believe you need the cans. with airlockers you dont. |
| Author: | sideways [ Mon Jul 23, 2012 2:24 pm ] |
tanshi wrote: you using open centres? if so i believe you need the cans. with airlockers you dont. Cheers. I'm tossing up between a Spartan or a Chinese air locker, sounding more and more like an airlocker is the way to go though. Is the tooth count the same as LJ50 gears? |
| Author: | tanshi [ Mon Jul 23, 2012 2:36 pm ] |
from what i can find the tooth count is 8/39 |
| Author: | sideways [ Mon Jul 23, 2012 2:40 pm ] |
tanshi wrote: from what i can find the tooth count is 8/39 Thanks again! You guys still building those centred 1.3l diffs? |
| Author: | tanshi [ Mon Jul 23, 2012 2:56 pm ] |
its still in the works i believe. |
| Author: | sideways [ Mon Jul 23, 2012 2:57 pm ] |
Cool. |
