| Long range tank. Re-routing exhaust ? https://auszookers.com/forum/viewtopic.php?f=5&t=34759 |
Page 1 of 2 |
| Author: | dono1 [ Mon Aug 06, 2012 12:27 pm ] |
| Post subject: | Long range tank. Re-routing exhaust ? |
Does anyone have some pics of a swb sierra with a longrange tank fitted showing where the exhaust goes? |
| Author: | bigal [ Mon Aug 06, 2012 10:48 pm ] |
| Post subject: | Re: Long range tank. Re-routing exhaust ? |
ye had to fit the exhaust out the side just in front of rear wheel. will try to get pics up later |
| Author: | foolsp33d [ Tue Aug 07, 2012 12:22 am ] |
This way is better than... ![]() This way... ![]() ![]() top shows exhaust running OVER the chssis rail.. but you will more than likely need a BL to do so... |
| Author: | atari4x4 [ Tue Aug 07, 2012 12:28 am ] |
sidepipes FTMFW |
| Author: | dono1 [ Tue Aug 07, 2012 8:14 am ] |
I've done this for now bit there has to.
| Author: | BlueSuzy [ Tue Aug 07, 2012 1:27 pm ] |
you could probably run it over the diff then through the spring then next to the spring. Depending on how much room i guess Sheepload better than that position |
| Author: | got_bar_work [ Tue Aug 07, 2012 1:58 pm ] |
Go buggy style and notch it into the chassis rail and out again at the back Dont know how legal it would be |
| Author: | dono1 [ Tue Aug 07, 2012 7:20 pm ] |
Its only a temporary fix at the moment. |
| Author: | boostedbrick [ Tue Aug 07, 2012 7:32 pm ] |
My tank lift has the tank against the left chassis rail, the exhaust went under the chassis and kicked in near the shackle. Should be heaps of room in there to fit an exhaust... |
| Author: | dono1 [ Tue Aug 07, 2012 8:38 pm ] |
These are some dodgy pics but they might show how little room.i have to play with ![]() ![]()
| Author: | atari4x4 [ Tue Aug 07, 2012 8:51 pm ] |
chrome stacks?
| Author: | boostedbrick [ Wed Aug 08, 2012 7:34 pm ] |
You have as much room as I do. But the top of my shocks are inboard quite a bit. A decent exhaust shop would have to be able to make something fit in there.. I made mine fit with some scrap exhaust bits and some old bends.. |
| Author: | foolsp33d [ Sun Aug 12, 2012 10:44 pm ] |
| Author: | KEENSY85 [ Mon Aug 13, 2012 2:19 am ] |
atari4x4 wrote: sidepipes FTMFW Funny bastard ,I agree |
| Author: | dono1 [ Mon Aug 13, 2012 7:17 pm ] |
foolsp33d wrote: ![]() ![]() I think this is what ill do when my bodylift gets here. once that goes in I should have plenty of room. |
| Author: | KEENSY85 [ Tue Aug 14, 2012 3:37 am ] |
I don't mind that look I might even look at ot my self just a warning though its got to be out the drivers side in qld ,I don't know about other states ,and on a 45 degree angle down and back . They get worried about fumes blowing on to the footpath .and before some. Dumbass says something smart its a fact I actually rang main roads about it |
| Author: | Hybrid [ Tue Aug 14, 2012 12:56 pm ] |
Is that a custom long range tank tank Dono? Before I modded my long ranger tank I kicked my exhaust in to run along under the chassis. It starts roughly around center spring (near the bump stop) then runs the length of the back half of the spring, exiting next to the shackle. The spring protects it from the getting crushed. Baah! Just looked back and from what I can see I take it yours is a narrow track? That rules my method out. With regard to the side exhaust I was told years ago by DOT that it has to discharge behind the last unsealed body seam. When I was speaking to them they were referring to getting it behind the back doors. Seeing as ours run a rear tail gate that accesses the whole cab I don't see how, in Queensland at least, are legal. Not that I do everything by the book but its a really obvious thing for them to pick. See below an excerpt from the QLD mod rules I picked up with a quick google. The exhaust outlet must extend at least 40mm beyond the furthermost outboard or rearmost joint of the floor pan that is not continuously welded or permanently sealed which could permit direct access of exhaust gases to the passenger compartment, but not beyond the perimeter of the vehicle when viewed in plan. |
| Author: | dono1 [ Tue Aug 14, 2012 1:30 pm ] |
Yeh mine is a narrow track... |
| Author: | KEENSY85 [ Tue Aug 14, 2012 2:27 pm ] |
Hybrid wrote: Is that a custom long range tank tank Dono? Before I modded my long ranger tank I kicked my exhaust in to run along under the chassis. It starts roughly around center spring (near the bump stop) then runs the length of the back half of the spring, exiting next to the shackle. The spring protects it from the getting crushed. Baah! Just looked back and from what I can see I take it yours is a narrow track? That rules my method out. With regard to the side exhaust I was told years ago by DOT that it has to discharge behind the last unsealed body seam. When I was speaking to them they were referring to getting it behind the back doors. Seeing as ours run a rear tail gate that accesses the whole cab I don't see how, in Queensland at least, are legal. Not that I do everything by the book but its a really obvious thing for them to pick. See below an excerpt from the QLD mod rules I picked up with a quick google. The exhaust outlet must extend at least 40mm beyond the furthermost outboard or rearmost joint of the floor pan that is not continuously welded or permanently sealed which could permit direct access of exhaust gases to the passenger compartment, but not beyond the perimeter of the vehicle when viewed in plan. I did it on a 1 tonne rodeo ute so the facts u state above I think u might be right wich is a pity cos it looks bitchen hanging out the side;( |
| Author: | dono1 [ Tue Aug 14, 2012 3:08 pm ] |
Commercial vechiles (utes,trucks and vans)fall into their own category in nsw. |
| Author: | got_bar_work [ Tue Aug 14, 2012 6:15 pm ] |
Isnt a sierra regoed as a ute |
| Author: | foolsp33d [ Tue Aug 14, 2012 6:18 pm ] |
Station wagon here :/ No idea how they came to that conclusion.. but is.. :/ |
| Author: | KEENSY85 [ Tue Aug 14, 2012 10:18 pm ] |
My vin plate says utility its a 85 |
| Author: | foolsp33d [ Tue Aug 14, 2012 10:29 pm ] |
but what does the rego sticker say!? :/ |
| Author: | got_bar_work [ Wed Aug 15, 2012 4:10 am ] |
I think hardtops were stationwagon Thrre has been so many different ones ive heard off Think some were panelvan |
| Author: | sando [ Wed Aug 15, 2012 5:59 pm ] |
My old hardtop that came with no rear seats had van on the id plate. Was registered as a van, strange looking van if you ask me.... |
| Author: | dono1 [ Wed Aug 15, 2012 7:31 pm ] |
My old 1L softop was a utility on the reno and comp. plate |
| Author: | jdk81 [ Mon Aug 27, 2012 5:21 am ] |
mazdaspater wrote: Got some pics of mine, a bit outside the box. Seems to work though. WT diffs under NT so I went outside chassis. Have to get a full stuff photo. Does it scrub on the wheels during articulation? |
| Author: | mazdaspater [ Mon Aug 27, 2012 8:02 pm ] |
Gotta do some more dumb stuff to see, it has only been on a couple weeks. I just ran it through some huge muddy ruts diagonally for a bit to see if it did but ended up getting stuck due to one hub not being locked properly. Never let a Subaru driver lock your hubs. There was no polished section on the pipe though so that has to be a good sign. As I said, gotta jack it up and take a full stuff photo. |
