It is currently Fri Nov 06, 2026 10:53 pm
Vehicle: SWB Vit & LWB GV
Post Posted: Mon Dec 19, 2011 9:18 am
Hey guys,
Just wondering if there is trick to remove the top bolt of the fuel filter holder. I can't get a socket, spanner or screw driver in there. So far, I've have only tried from underneath. Would removing the wheel help?
Also, in the FSM it says to remove the fuel pump relay and crank the engine a few times to release the pressure. Can I also just remove the Fuel Injection fuse and crank it over?
Cheers.
stock as a rock
Post Posted: Tue Dec 20, 2011 12:05 am
relay is just as easy as the fuse.
Post Posted: Tue Dec 20, 2011 4:06 am
Cheers B4T. Any advice on removing the filter?
stock as a rock
Post Posted: Tue Dec 20, 2011 5:28 am
X2, the idea is to drop the pressure in the line...
Top bolt's are a prick, from memory I used to jack the chassis up, but can't remember what side.... ( cocking a led basically)
& it has been known for that bolt to not go back in..... :helloo:
Post Posted: Tue Dec 20, 2011 7:16 am
I'm going to remove the wheel and cock it's leg and see if I can get in from there.
stock as a rock
Post Posted: Tue Dec 20, 2011 9:46 am
top bolt isnt that hard to get to !!
and the reason behind the disabling the relay and not the fuel injection fuse is this .. without the fuel injection fuse the injectors wont fire , hence you wont relieve any pressure that is currently in the rail , by disabling the relay , the fuel wont pump , but the injectors will relieve the pressure ..
Vehicle: 2002 GV V6 and self shifter
Post Posted: Sun Mar 11, 2012 6:37 pm
Bit of a thread revival while I was searchin for something else
Here is a thread I started on the GV fuel filter. Maybe it's of use here, not sure.
Vehicle: LJ80
Post Posted: Sun Mar 11, 2012 7:01 pm
have you got to 10k yet ?
Post Posted: Sun Mar 11, 2012 7:32 pm
Where is the fuel pump relay? I changed the filter last weekend and once the 2 hoses were removed, about 100mL of fuel came out.
I took the wheel off and it was heaps easier to get too. A ratchet spanner would have been perfect to get the top bolt off, but not necessary. I reinstalled without the top bolt.
stock as a rock
Post Posted: Sun Aug 12, 2012 10:39 pm
Left filter in for ~15k kms. Have updated other thread now.
Users browsing this forum: No registered users and 108 guests
