It is currently Fri Nov 06, 2026 9:14 pm
Vehicle: zook buggy
Post Posted: Sun Sep 02, 2012 10:18 am
whats the go what do i need? 1.6mpfi early ish 1 goin into a buggy, not using any sierra harness, just goin to chop of any unneccessary crap from the vit harness and use that, also its a denso ecu :?
Post Posted: Mon Sep 03, 2012 6:20 pm
if you dont want to play with wiring the 3.0 pajero auto is a vac shifted aw4 or what ever the 4 speed is or they is a aftermarket baja shifter that you wire strait to the box
Vehicle: zook buggy
Post Posted: Mon Sep 03, 2012 9:01 pm
the 3speed is vac shifted aswell, theres stuff like neutral start switch which i have no idea were to hook up to, and from memory the lockup part of the convertor has been removed.
Vehicle: zook buggy
Post Posted: Wed Sep 05, 2012 8:40 pm
obviously to hard a question :deadhorse:
Vehicle: LJ20 LJ50
Post Posted: Wed Sep 05, 2012 8:45 pm
Well obviously. so fuck off.....
Vehicle: zook buggy
Post Posted: Wed Sep 05, 2012 8:46 pm
wtf retard
Vehicle: LJ20 LJ50
Post Posted: Wed Sep 05, 2012 8:51 pm
bazooked wrote:
wtf retard
Well I see like this. You want an answer and get shitty when no one tells you what to do exactly, within two days. If you cant work out how to bypass a neutral switch or build your own then I guess we are the fucking retards arnt we.
Your post could be taken that we are all retards who cant help you cause we are to busy licking the windows and fidgeting with our stackhats to type out an exact way of you doing what you need to do. Well thats the way I read it. so I said Fuck off. Simple.
Do you have a better explanation for your arragant fucked up little hissy fit of a post???
Vehicle: zook buggy
Post Posted: Wed Sep 05, 2012 9:06 pm
lmao you got all that out of a few words on the internet?, i believe someone has issues and needs a visit from doctor phil!, obviously im no electrical genius, and asked the said question, i must be mistaken and joined i don't give a fuck tzars forum.
Vehicle: 4wd
Post Posted: Thu Sep 06, 2012 9:16 am
No you joined Auszookers, less then 2 months ago and have contributed nothing, but are expecting others to help you out.
The question you want answering isn't something that many people on here would know about. I'd say the people who do might only visit weekly or so. A little more time and you might of got the answer you needed. Not sure if you will get it now.
:deadhorse:
Watch out or you'll get sued.
Post Posted: Thu Sep 06, 2012 10:18 am
The first problem is figuring out what the heck he's asking - the only thing that's clear is that both 3 & 4 speed automatic transmissions are involved.
Is it ...
a) Wiring what was originally a 3 speed vehicle to use a 4 speed transmission
or ...
b) Wiring what was originally a 4 speed vehicle to use a 3 speed transmission.
The first case will need more than just wiring - since the 4 speed is electronically shifted - the same might also apply to the second case, since the TCU will throw some sort of a code when it doesn't see the transmission, and the ECU likewise if the TCU is removed.
Post Posted: Thu Sep 06, 2012 10:24 am
should have asked the suzuki gods on outers. :lol:
Vehicle: zook buggy
Post Posted: Thu Sep 06, 2012 7:33 pm
sorry didnt realise there was a qualifying period to answer questions on a dedicated suzuki forum!
as for the original question, there was a 4speed bolted up before, no longer running that or the comp that comes with it
Vehicle: 4wd
Post Posted: Thu Sep 06, 2012 7:35 pm
Obviously didn't read the rules. :deadhorse:
Vehicle: zook buggy
Post Posted: Thu Sep 06, 2012 7:41 pm
obviously a couple of my mates were right about this forum :deadhorse:
Post Posted: Thu Sep 06, 2012 7:48 pm
I thought the 3 speed box was all mechanically operated. In regards to the ECU of the MPFI engine just leave the auto wires disconnected. ECU will run no probs
Post Posted: Thu Sep 06, 2012 8:49 pm
What is most annoying is when people search for info about installing aw4 etc with custom setups will come to this thread where you have shown yourself as the biggest cockhead in recent times.
It almost appears that you are trolling, being a nutgobbler to people just for kicks.
Jrzook gave you the simple answer, which doing searches would have indicated anyway.
I'm not surprised you didnt search, the answer would have been on the wiring diagrams for vit with 3 speed auto.
You have heard of google and the search button?
A better explained first post may have also helped people answer you quicker.
I intially thought you were asking about running an aw4, where a 3speed auto was. Significantly more complicated.
A topic similar to that was posted a few months ago. I believe Jrzook piped up with a bit of good tech in it.
I was tempted to answer you a few times earlier, but deleted what I had typed and walked away because of the online persona you are projecting.
If you are genuine, you arent doing yourself any favours.
If the company you keep also has a problem with this forum, perhaps consider that you and your circle of friends should reconsider your membership on this forum.
This place is full of many people, some really piss me off at times....atari hehe... but generally its a cool forum.
Vehicle: zook buggy
Post Posted: Thu Sep 06, 2012 9:05 pm
me the cockhead? for real? maybe i worded it incorectly, my bad!, but it doesnt give keyboard warriors the right to go of on an abusive tangent!, thanks to the people that have answered , no im not a troll and no im not in high school! and im sorry i didnt ask the obvious question of what shackle angle my missing links should be
Users browsing this forum: Google Adsense [Bot] and 86 guests
