It is currently Fri Nov 06, 2026 7:32 pm
Post Posted: Tue Sep 04, 2012 9:58 am
Alright... who's done it???
Mines leaking all over my foot again even though i've got the vent mostly covered!!! The drain holes are clean, but behind that plastic bit under the vent's grille i can see is full of leaves, and there's no way i can see of getting in there to clean it.
Has anyone ever managed to get in there and clean it out, cos its driving me nuts!
Post Posted: Tue Sep 04, 2012 11:37 am
Mine was cleaned out by a fire but you probably don't want to go to that level. Have you tried sticking compressed air down the drain holes and in through the top from the vent? Normally clears a fair bit of leaves out.
Vehicle: SJ51T
Post Posted: Tue Sep 04, 2012 11:47 am
take the drainage pipes off, using a combination of a coat hanger through the top, fingers at the bottom holes and a hose through the top/ bottom will have it cleaned out in no time.
when i rebuilt my ute i put gauze over the top of the vent. no more leaves in my vents..
Post Posted: Tue Sep 04, 2012 4:06 pm
you talking about the drainage pipes inside the cab right? I've not looked that far up there (hard with a dash in the way).
Vehicle: LJ80
Post Posted: Tue Sep 04, 2012 4:28 pm
your heater will probably be full of leaves as well
this worked well for me. but i silastiked a cover on the hole after :roll:
http://www2.izook.com/?page_id=258
bit of a blast of air up from the bottom while vac ing helped get all the bits out
Post Posted: Tue Sep 04, 2012 4:30 pm
yeah i've done the heaterbox cleaning thingo... worked as far as making the heater work better, but certainly didnt help the leaking.
Vehicle: SJ51T
Post Posted: Tue Sep 04, 2012 5:44 pm
yep thats them. you'll probably need to pull them out to properly clean it, my one old was clogged so badly a hose wouldnt blow all the crap out
Dont need to look, just get your fingers up there and have a feel :wink:
Post Posted: Tue Sep 04, 2012 10:59 pm
righto - i'll give that a shot and see what happens... do they just pull out and plug back in or is there some clamp trickery going on???
Vehicle: SJ51T
Post Posted: Wed Sep 05, 2012 12:06 am
They just pull off. Probably one of the reasons they leak even when clean...
Post Posted: Wed Sep 05, 2012 8:31 am
i wonder if those plastic clamps used for reticulation would help them seal better once re-installed?
Post Posted: Sat Sep 08, 2012 5:14 pm
righto - i took of the rubber hoses on both sides, and while they werent blocked, the box bit they join to on each side was pretty clogged... so i jammed wire up there and rammed it around while flushing water in via a hose in the vent outside... got both sides clean as, reconnected the hoses and gave it a blast with the hose... and low and behold.... THE LEAK IS STILL FUCKING THERE!!! GRRRRRR!
Its only leaking on the drivers side, and its coming from right up the top (can see water up there when i shine a torch up). Its running down the outside of the air hose that goes to the foot heater, as well as splashing up around the top of the dash.
is there another hose or seal of some sort behind the dash that i'm missing here??? (assuming its where the airbox part connects to the vents)? Please dont tell me the dash needs to come out to fix this...
Vehicle: SJ51T
Post Posted: Sat Sep 08, 2012 5:31 pm
I didnt find any other seals in that area when I did my rebuild. Sounds like the dash will have to come out. also if the cause is a damaged leaf/water catcher; you have to get a replacement from the same model, NT and WTs have different mounts.
Post Posted: Sat Sep 08, 2012 6:04 pm
if its cracked somewhere i'd just sikaflex the shit out of it =) way cheaper! lol
bugger taking the dash out though, i dont have the patience for that.
good thing summer is on the way huh? =)
Vehicle: SJ51T
Post Posted: Sat Sep 08, 2012 6:20 pm
hahah!
It would only take 2hours at most to pull it down and put it back together.
Would be a good opportunity to put some mesh over the vent as well!
Dont be lazy!!!
Post Posted: Sat Sep 08, 2012 6:23 pm
You can thank me later
viewtopic.php?f=14&t=3956&hilit=Wet+foot+stopper
Post Posted: Sat Sep 08, 2012 6:40 pm
matty_wall wrote:
hahah!
not at the rate i work at... lol
tried a quick search, but can't find anything in removing a WT dash??? any ideas? If i'm going to do it i'd rather make sure im not going to break anything!
haha yeah i've had magnets on there temporarily, but i do like to use the fan for external air now and then, so covering completely doesnt appeal to me =)
Users browsing this forum: Google [Bot] and 85 guests
