It is currently Fri Nov 06, 2026 9:14 pm
Post Posted: Wed Sep 05, 2012 7:17 pm
Hi everyone,
just wondering where the breathers are situated on the gearbox and transfer case of a 92 Sierra, also do you have to tap into them to fit breathers or can you do a similar thing to breathers on the diffs?
Any help would be great!
Post Posted: Wed Sep 05, 2012 7:25 pm
The gearbox breather is on the top of the box above the arrow pointing to the bolt.
do a search, they have been fitted with breathers before, but do bear in mind that the shifter is really badly sealed and is only 1.5" higher up.
and:
viewtopic.php?f=5&t=31496&hilit=transfer+case+breather
Search is your friend.
Post Posted: Wed Sep 05, 2012 7:32 pm
Thanks heaps for your help Steve! Now with the breather on top of the gearbox I searched and people have said that the holes are on the side so if you place a hose over the top it will block the holes! Any suggestions? Could you maybe cut the top off?
Post Posted: Wed Sep 05, 2012 7:38 pm
You are correct, the holes are on the sides. Ideally pull the cap out, tap the box for a 90˚ barb and put a hose on that, but as I said, do consider that it's tough to seal the shifter so it might be a bit pointless.
Post Posted: Wed Sep 05, 2012 7:42 pm
Ok maybe forget extending the breathers on the gearbox then if it's gonna be a sieve in other places haha. But is the shifter on the transfer the same?
Post Posted: Wed Sep 05, 2012 8:14 pm
It seals better (and is easier to seal)
I've filled a transfer with mud and water twice. Never a gearbox.
Post Posted: Wed Sep 05, 2012 8:25 pm
Ok noob question how do you seal up the shifter? What do you use ect?
Post Posted: Wed Sep 05, 2012 11:42 pm
The shifter on the gearbox should have a round rubber boot over it covering the top plate with 3 bolts
The shifter on the transfer should have one also, but with a metal band that wraps around it holding it in place in a groove
Users browsing this forum: Google Adsense [Bot] and 84 guests
