It is currently Fri Nov 06, 2026 7:31 pm
Vehicle: 89 w/t sierra
Post Posted: Fri Sep 07, 2012 6:07 pm
it seems as if the 4wd gear stick is stuck in neutral,i cant seem to move it. i hope this uis just a nood thing on my behalf. any suggestions?
also my handbrake doesnt make the ratchet noise when putting the hand brake on?
thanks, Josh Green.
Post Posted: Fri Sep 07, 2012 6:14 pm
Josh,
You need a new shifter bush. PM myself or bruce. We can fix you up with a new one :wink:
Post Posted: Fri Sep 07, 2012 6:16 pm
do you know anything about the handbrake?
Vehicle: 1985 Holden Drover
Post Posted: Fri Sep 07, 2012 6:32 pm
Afaik thatd just be the teeth clicking over?
Post Posted: Fri Sep 07, 2012 6:35 pm
yeah it doesnt make that noise
Post Posted: Fri Sep 07, 2012 6:40 pm
Can you see what the lever is doing when you pull it up?
Post Posted: Fri Sep 07, 2012 6:42 pm
not really cos there is a center console
Does it lock on ? Does the button in the end of the handle pop in and out ?
Post Posted: Fri Sep 07, 2012 6:43 pm
yeah it does
Vehicle: 91 WT 1.6EFI
Post Posted: Fri Sep 07, 2012 6:44 pm
When my lever was stuck in neutral it was packed full of sand. I just pulled it out on the track and got it all out. Might be worth a look, but having said that it's probably the shifter bush
Post Posted: Fri Sep 07, 2012 9:32 pm
Josh,
Hey Pete, can you get the bush that suits the early non-switched case?
Post Posted: Fri Sep 07, 2012 10:10 pm
sideways wrote:
Josh,
I have a heap here. I wasn't aware of any difference. Got a pic?
Post Posted: Sat Sep 08, 2012 2:32 pm
sideways wrote:
Josh,
No pictures because I don't have a bush, it's actually worn a nice groove into the transfer body! The old one was just a few tiny chunks of plastic scattered throughout the case.
As far as I can tell, it's just a smaller diameter and a bit shorter. Suzistore said they were the same (I asked after an eBay seller said they were different) so I bought their shifter kit and the only bit that fitted was the boot (didn't try the detents ect) but the collar and bush were slightly to large to fit. The bush kinda fitted but it disintegrated whilst I was trying to fit it. :x The diameter was to large and it didn't fit under the bolt that guides the stick.
I've been running it with no bush for months now, it's always a nervous moment when I shift into low range. :lol:
Users browsing this forum: Google [Bot] and 79 guests
