It is currently Fri Nov 06, 2026 8:35 pm
Vehicle: 92 sierra tintop, 88 WT sj50
Post Posted: Sun Sep 09, 2012 5:21 pm
hey guys. just purchased a 92 sierra last night. Found a stack on receipts in glove box. In 2009 previous owner has installed rancho shocks all round, tough dog steer dampner, new springs and bushes. Now theres not a lot of info on the receipt but just wondering how i can measure to figure out if springs are standard height or not. tyres are 205/75/15 and they look like they have 50-60% left. And a 375ml can of coke fits snug between the tyre and flare on the front, and has about 10mm gap from tyre to flare on rear
any help is much appreciated
cheers
Post Posted: Sun Sep 09, 2012 5:40 pm
Seems very unbalanced in height ..
But on 205's if there is a 10mm gap especially I'd say they're standard height.
Post Posted: Sun Sep 09, 2012 5:46 pm
i still havnt checked up on tyre pressures but is a 10mm difference front to rear a huge deal?
Post Posted: Sun Sep 09, 2012 6:05 pm
Oh do you mean 10mm gap between coke can and flare on rear?
Post Posted: Sun Sep 09, 2012 7:01 pm
yeah. 10mm gap between top of can and flare on rear
on front the can is snug. probably weight of motor etc
Post Posted: Sun Sep 09, 2012 7:17 pm
oh im with ya now. first description made it sound like 10mm between tyre and flare.
THis is standard 205's and stock springs.
Post Posted: Sun Sep 09, 2012 7:43 pm
this is mine
Post Posted: Sun Sep 09, 2012 8:36 pm
Looking at the leaf spring I'd say they are lifted springs.
Post Posted: Sun Sep 09, 2012 9:06 pm
maybe a slight 1inch or 1.5 inch lift.
Post Posted: Mon Sep 10, 2012 10:20 pm
Checked the tyre pressures today. 28psi all round. But rides like a pig lol. Throws me around like a rag doll haha
Post Posted: Tue Sep 11, 2012 2:17 am
Did you check the recommended pressures on the tyre placard? Drop your pressures to 21psi like it says, will improve the ride.
Post Posted: Tue Sep 11, 2012 6:17 am
21psi sounds too low lol. Won't that wear tyres prematurely??
Post Posted: Tue Sep 11, 2012 6:22 am
NO.
From the factory, 21psi.
Post Posted: Tue Sep 11, 2012 6:46 am
Sounds like a plan ! Thanks 303zuke
Post Posted: Tue Sep 11, 2012 1:04 pm
Stock bump to diff is 50/60mm
Other info: Stock bumpstop heights according to Transport Tas should be -
Front 40mm, Rear 75mm.
More talk here:
viewtopic.php?f=5&t=18959&p=318406&hilit=standard+height#p318406
Users browsing this forum: Google [Bot] and 95 guests
