It is currently Fri Nov 06, 2026 7:19 pm
Post Posted: Tue Sep 11, 2012 7:27 pm
Is anyone using an engine immobilizer? I have done a search and haven't found anything useful.
I want to put one in my brothers sierra with a g16b, I found some cheap ones for around $90 and expensive ones for triple that.
Any advice?
Post Posted: Tue Sep 11, 2012 7:53 pm
My Vitara came with one, fitted by original owner.
I can't find it, too well hidden, so can't tell you the make.
But it has worked flawlessly since I owned it.
It comes on with the remote central locking.
NB: don't leave keys and dog in car,
she locked herself in, and me out once.
Post Posted: Tue Sep 11, 2012 7:55 pm
Dynamco
Post Posted: Tue Sep 11, 2012 10:54 pm
Run a hidden kill switch.
You don't want aftermarket alarm crap
Post Posted: Wed Sep 12, 2012 9:35 am
I run this on my go-slow car (Vitara) and my go-fast car (Legnum):
Cyclops P375B $350 Installed
Black wiring
Twin Point Immobiliser - Starter Motor + Ignition (ECU, Fuel Pump, Ignitors)
Bonnet, Doors, Tailgate
Glass Breakage Sensor
I like it because it uses 30A relays which means you can immobilise the higher power stuff like the starter motor, fuel pump etc. A lot of other alarms have 10A relays which means you are limited to what you can immobilise.
If you go the full alarm route (like above) don't get motion sensors, they are horrendously unreliable and get triggered on windy days.
Post Posted: Wed Sep 12, 2012 9:51 am
viewtopic.php?f=5&t=35667
Ive also had a civic with an aftermarket alarm. Thing used to go off in the middle of the night. Useless fucking things
Post Posted: Wed Sep 12, 2012 10:44 am
Black wiring
your not limited??
just add a larger relay to it so the small relay drives the larger relay. problem solved.
Post Posted: Wed Sep 12, 2012 11:28 am
Black wiring
your not limited??
Or just get one with it already done so less fiddling and hassle!
Never had a false with any of my alarms...
Post Posted: Wed Sep 12, 2012 11:13 pm
Some good stuff in here, thanks
I like this, I was thinking something similar but with a hidden fuse. Might just do both now...
Post Posted: Thu Sep 13, 2012 4:40 pm
Black wiring
that's very similar to the set up i'm running in the silver trollop, Cyclops are a very reliable unit... I know someone who's literally fitted 100's of these over the years & puts a lifetime warranty on the unit & the install.
Cyclops fall under the Dynamco banner & are one of only a few that meet the australian standard
http://www.dynamco.com.au/products_prev ... model=P755
Users browsing this forum: Google [Bot] and 115 guests
