It is currently Fri Nov 06, 2026 8:35 pm
Vehicle: 1993 vitara
Post Posted: Mon Sep 10, 2012 6:24 pm
Hi i have a suzuki vitera 1993 and i took the gear box out to fix some leaks and notised
there is oil in the gearshift lever case should there be oil there or not i have drained the
box and the oil is still there
Thanks
Peter
Post Posted: Tue Sep 11, 2012 10:57 pm
I'm inclined to say it's not normal, however, it's also not unusual - the Vitara shift is on an extension which does not have oil circulating through it, but becaused it is not sealed, oil may make it's way in, among other reasons, the breather is a part of the shift extension.
If it's a large quantity, someone may have attempted to fill the transmission through the shift extension - in my opinion it's unlikely to cause any problems, but i I would wipe it out with a rag and use a multi-purpose grease to lube the shift seat & cup when reassembling.
Post Posted: Wed Sep 12, 2012 8:24 pm
Thanks fordem
I took it off and wiped out and regreased it i think someone ahs tried to fill it wrong
Thanks
Peter
Users browsing this forum: Baz89, Google [Bot] and 93 guests
