It is currently Wed Nov 04, 2026 12:10 pm
Post Posted: Sat Sep 29, 2012 4:50 pm
Hi guys,
Been running my SWB vitara on the dobinsons 2" lift from dank for some time now.. extended struts yadayada yada.. I have grown sick of it being to stiff and Im Looking for ways to retain my lift but change the springs.
So, If i put my stock springs back in, where can I find 25mm/50mm coil spacers to get it upto height again? done a couple of searches and could only find 15/30..
OR.. what softer springs are there that I can swap straight in??..
Cheapest way out perffered.
Cheers, Mark!
Post Posted: Sat Sep 29, 2012 5:02 pm
Ask Bruce for what ya want as he will proberbly have them
Post Posted: Sat Sep 29, 2012 5:25 pm
Yep I can help. I make spacers to suit 99.9% of all 4x4s from 10mm to 50mm :wink:
Post Posted: Sat Sep 29, 2012 6:25 pm
What about Ssanyong Mussos??
Location: Southside Brisbane- the best side of the river
Vehicle: Shitbox
Post Posted: Sat Sep 29, 2012 6:27 pm
anything in stock for great walls?
Scrawn wrote:
Signatures are shit anyway
Post Posted: Sat Sep 29, 2012 6:33 pm
What about jeeps :?: :oops:
Post Posted: Sat Sep 29, 2012 6:46 pm
And are the parts flameproof? (double whammy there with shep needing the parts....)
Post Posted: Sat Sep 29, 2012 6:52 pm
No and really not worth it cause there is no call for it and I think the rear's are leaf and the front of coil over.
Post Posted: Sat Sep 29, 2012 6:53 pm
You may as well be talking about the Holden Rodeo
Yep do a lot of Jeeps. :wink:
Post Posted: Sun Sep 30, 2012 6:27 am
So how much for a set of 25/50mm spacers for my vitara Bruce? And shipping to 3021 VIC.
Cheers. Mark.
Vehicle: Jeep
Post Posted: Mon Oct 01, 2012 8:14 pm
Are you sure its your springs, and not your tyre air pressure, to much air in them can give a very stiff/harsh ride...
Most spring manufacturers, make springs with different rates, Comfort, Performance/Light load, Med load, and Constant load...
Lifted springs will always be better than stock springs and spacers, they just wont have the same amount of travel or performance, stocks are basically road springs... maybe just buy some comfort lifted springs... :D
Vehicle: WR250F/Jeep XJ
Post Posted: Mon Oct 01, 2012 8:56 pm
Mark Dobinsons occasionally get this complaint from some customers and they have had good success in ride quality changes by swapping out the shocks for an ultima shock or stockish brand replacement shock with softer valving. So it's not the coils in alot of cases. The shocks with the kit are a big bore shock so if you havent got a lot of weight or accessories this is what you might be finding that the shock damping rate is a bit much.
Only an idea that I have discussed with dobinsons in the past but thought you'd like to know.
Post Posted: Mon Oct 01, 2012 10:54 pm
True dat ^^^
I was running Tough Dog lifted GV coils and shocks in the rear, was spine-compactingly harsh with an empty boot. Swapped the shocks out for some Ranchos, now it's a million times better.
Post Posted: Mon Oct 01, 2012 11:00 pm
Alot of ranchos that suit zooks will cross reference to a dual shock application from a F truck so they are not a bad option.
Post Posted: Tue Oct 02, 2012 5:16 pm
thanks for the replies guys..
Have already ordered coil spacers though.. I will swap the shocks out to the stock ones just to see if it is actually the shocks or not..and then buy some others if it is and could probably sell the coil spacers off.
no biggy.
will post progress :)
Post Posted: Wed Oct 03, 2012 6:35 pm
swapped out the rear shockies to the stock ones and made a really good improvement! Thanks for the info Dank and others!
Now, have you guys that have swapped out the dobinsons shocks for others also swapped the front struts?
What shocks should I buy now?... was thinking of just going with the commodore ones because I want to do this on the cheap, whilst still getting as much comfort as possible.
would appreciate some insight =]
Cheers, Mark.
Post Posted: Thu Oct 04, 2012 3:12 pm
Commonwhore seem to be the best bet for budget and soft-ish ride.
Post Posted: Thu Oct 04, 2012 4:26 pm
i rate the ride with the commy shocks in the bum of the vits, although i've never used any of the name brand big bore shocks they just seem like overkill
Post Posted: Thu Oct 04, 2012 6:43 pm
Hey mate can you get Rancho's? If so im keen on some from the rear of a Pajero.....from about a 2000 model.
Post Posted: Mon Oct 08, 2012 6:09 pm
Hey guys, done a heap of reading about commo shocks in the rear of vits... bloody confusing!
What part number would i be looking for when wanting shockers to suit a 2" lift for the rear of my vit!??
any that will fit that have the same rubber bush sizing? would be nice:) lol..but no biggy , can always swap em.
Hope you can help! Mark.
Post Posted: Mon Oct 08, 2012 7:51 pm
ask for vp/vn ones, you have to make a sleeve for the bush for them to fit
iv run the dobinsons coils and these shocks for more than a year and ride is very nice and flexes well
Vehicle: 1989 Suzuki Vitara JX
Post Posted: Sun Apr 14, 2013 7:12 pm
Are VN shocks f=good for front and rear? i wouldnt mind knowing the CHEAPEST way to lift 2" if anyone can help?
Post Posted: Sun Apr 14, 2013 7:18 pm
Fronts are struts and you need actual vitara ones for the front.
Post Posted: Sun Apr 14, 2013 8:03 pm
Yeh just had a look around and found the right topic, thanks
Users browsing this forum: Google [Bot] and 75 guests
