| Had enough! Vit commo shocks??? https://auszookers.com/forum/viewtopic.php?f=5&t=36040 |
| Author: | ms1991 [ Sat Sep 29, 2012 4:50 pm ] |
| Post subject: | Had enough! Vit commo shocks??? |
Hi guys, Been running my SWB vitara on the dobinsons 2" lift from dank for some time now.. extended struts yadayada yada.. I have grown sick of it being to stiff and Im Looking for ways to retain my lift but change the springs. So, If i put my stock springs back in, where can I find 25mm/50mm coil spacers to get it upto height again? done a couple of searches and could only find 15/30.. OR.. what softer springs are there that I can swap straight in??.. Cheapest way out perffered. Cheers, Mark! |
| Author: | shep [ Sat Sep 29, 2012 5:02 pm ] |
| Post subject: | Re: Had enough! |
Ask Bruce for what ya want as he will proberbly have them |
| Author: | Bruce [ Sat Sep 29, 2012 5:25 pm ] |
shep wrote: Ask Bruce for what ya want as he will proberbly have them Yep I can help. I make spacers to suit 99.9% of all 4x4s from 10mm to 50mm |
| Author: | Scrawny [ Sat Sep 29, 2012 6:25 pm ] |
What about Ssanyong Mussos?? |
| Author: | Mattmorgo [ Sat Sep 29, 2012 6:27 pm ] |
anything in stock for great walls? |
| Author: | shep [ Sat Sep 29, 2012 6:33 pm ] |
What about jeeps |
| Author: | mrw82 [ Sat Sep 29, 2012 6:46 pm ] |
shep wrote: What about jeeps And are the parts flameproof? (double whammy there with shep needing the parts....) |
| Author: | Bruce [ Sat Sep 29, 2012 6:52 pm ] |
Scrawn wrote: What about Ssanyong Mussos?? No and really not worth it cause there is no call for it and I think the rear's are leaf and the front of coil over. |
| Author: | Bruce [ Sat Sep 29, 2012 6:53 pm ] |
Mattmorgo wrote: anything in stock for great walls? You may as well be talking about the Holden Rodeo No and really not worth it cause there is no call for it and I think the rear's are leaf and the front of coil over |
shep wrote: What about jeeps Yep do a lot of Jeeps. |
| Author: | ms1991 [ Sun Sep 30, 2012 6:27 am ] |
Bruce wrote: shep wrote: Ask Bruce for what ya want as he will proberbly have them Yep I can help. I make spacers to suit 99.9% of all 4x4s from 10mm to 50mm So how much for a set of 25/50mm spacers for my vitara Bruce? And shipping to 3021 VIC. Cheers. Mark. |
| Author: | MacDaddy [ Mon Oct 01, 2012 8:14 pm ] |
Are you sure its your springs, and not your tyre air pressure, to much air in them can give a very stiff/harsh ride... Most spring manufacturers, make springs with different rates, Comfort, Performance/Light load, Med load, and Constant load... Lifted springs will always be better than stock springs and spacers, they just wont have the same amount of travel or performance, stocks are basically road springs... maybe just buy some comfort lifted springs... |
| Author: | dank [ Mon Oct 01, 2012 8:56 pm ] |
Mark Dobinsons occasionally get this complaint from some customers and they have had good success in ride quality changes by swapping out the shocks for an ultima shock or stockish brand replacement shock with softer valving. So it's not the coils in alot of cases. The shocks with the kit are a big bore shock so if you havent got a lot of weight or accessories this is what you might be finding that the shock damping rate is a bit much. Only an idea that I have discussed with dobinsons in the past but thought you'd like to know. |
| Author: | DarkHorse [ Mon Oct 01, 2012 10:54 pm ] |
True dat ^^^ I was running Tough Dog lifted GV coils and shocks in the rear, was spine-compactingly harsh with an empty boot. Swapped the shocks out for some Ranchos, now it's a million times better. |
| Author: | dank [ Mon Oct 01, 2012 11:00 pm ] |
Alot of ranchos that suit zooks will cross reference to a dual shock application from a F truck so they are not a bad option. |
| Author: | ms1991 [ Tue Oct 02, 2012 5:16 pm ] |
thanks for the replies guys.. Have already ordered coil spacers though.. I will swap the shocks out to the stock ones just to see if it is actually the shocks or not..and then buy some others if it is and could probably sell the coil spacers off. no biggy. will post progress |
| Author: | ms1991 [ Wed Oct 03, 2012 6:35 pm ] |
swapped out the rear shockies to the stock ones and made a really good improvement! Thanks for the info Dank and others! Now, have you guys that have swapped out the dobinsons shocks for others also swapped the front struts? What shocks should I buy now?... was thinking of just going with the commodore ones because I want to do this on the cheap, whilst still getting as much comfort as possible. would appreciate some insight =] Cheers, Mark. |
| Author: | DarkHorse [ Thu Oct 04, 2012 3:12 pm ] |
Commonwhore seem to be the best bet for budget and soft-ish ride. |
| Author: | atari4x4 [ Thu Oct 04, 2012 4:26 pm ] |
i rate the ride with the commy shocks in the bum of the vits, although i've never used any of the name brand big bore shocks they just seem like overkill |
| Author: | Built4thrashing [ Thu Oct 04, 2012 6:43 pm ] |
dank wrote: Alot of ranchos that suit zooks will cross reference to a dual shock application from a F truck so they are not a bad option. Hey mate can you get Rancho's? If so im keen on some from the rear of a Pajero.....from about a 2000 model. |
| Author: | ms1991 [ Mon Oct 08, 2012 6:09 pm ] |
| Post subject: | Re: Had enough! Vit commo shocks??? |
Hey guys, done a heap of reading about commo shocks in the rear of vits... bloody confusing! What part number would i be looking for when wanting shockers to suit a 2" lift for the rear of my vit!?? any that will fit that have the same rubber bush sizing? would be nice:) lol..but no biggy , can always swap em. Hope you can help! Mark. |
| Author: | larry [ Mon Oct 08, 2012 7:51 pm ] |
ask for vp/vn ones, you have to make a sleeve for the bush for them to fit iv run the dobinsons coils and these shocks for more than a year and ride is very nice and flexes well |
| Author: | kyleck [ Sun Apr 14, 2013 7:12 pm ] |
Are VN shocks f=good for front and rear? i wouldnt mind knowing the CHEAPEST way to lift 2" if anyone can help? |
| Author: | Chop [ Sun Apr 14, 2013 7:18 pm ] |
Fronts are struts and you need actual vitara ones for the front. |
| Author: | kyleck [ Sun Apr 14, 2013 8:03 pm ] |
Yeh just had a look around and found the right topic, thanks |
