https://auszookers.com/forum/
rear brakes!
https://auszookers.com/forum/viewtopic.php?f=5&t=3606
Author:  keg34 [ Sun Dec 21, 2008 8:40 pm ]
Post subject:  rear brakes!
Has anyone got any tips for removing rear brake drums?
Author:  Scrawny [ Sun Dec 21, 2008 8:43 pm ]
Post subject:  Re: rear brakes!
On what?
Sierras, you just need to remove the 4 nuts and it should drop off. It may take some encouragement from a hammer between the studs to loosen rust.
Not sure about Vitaras...
Author:  keg34 [ Sun Dec 21, 2008 8:45 pm ]
85 Sierra
Author:  nissvit [ Sun Dec 21, 2008 10:11 pm ]
undo the four nuts that hold the drum to the axle. . . leave the five wheel nuts tight, release handbrake(if W/T), kick around tyre.
the additional leverage will break the rust hold pretty quickly..
Author:  lump_a_charcoal [ Sun Dec 21, 2008 10:56 pm ]
gas axe
Author:  felix [ Sun Dec 21, 2008 11:14 pm ]
You can 'gently' tap the face of the drum with a hammer to release any corrosion present, then wiggle it off the handbrake.
