It is currently Mon Oct 19, 2026 11:44 pm
Post Posted: Sun Dec 21, 2008 8:40 pm
Has anyone got any tips for removing rear brake drums?
Post Posted: Sun Dec 21, 2008 8:43 pm
On what?
Sierras, you just need to remove the 4 nuts and it should drop off. It may take some encouragement from a hammer between the studs to loosen rust.
Not sure about Vitaras...
Post Posted: Sun Dec 21, 2008 8:45 pm
85 Sierra
Post Posted: Sun Dec 21, 2008 10:11 pm
undo the four nuts that hold the drum to the axle. . . leave the five wheel nuts tight, release handbrake(if W/T), kick around tyre.
the additional leverage will break the rust hold pretty quickly..
Vehicle: MY2019 Jimny
Post Posted: Sun Dec 21, 2008 10:56 pm
gas axe
Post Posted: Sun Dec 21, 2008 11:14 pm
You can 'gently' tap the face of the drum with a hammer to release any corrosion present, then wiggle it off the handbrake.
Users browsing this forum: Google [Bot] and 240 guests
