https://auszookers.com/forum/
doors
https://auszookers.com/forum/viewtopic.php?f=5&t=3646
Author:  Mike [ Sat Dec 27, 2008 8:50 pm ]
Post subject:  doors
someone once told me the top halfs of the doors on his zook were removable but they weren't soft top doors with vinyl windows
was this an option on sierras?
can standard doors be modified to do this?
mike
Author:  SJ413 [ Sat Dec 27, 2008 9:03 pm ]
Post subject:  Re: doors
i can't see why it couldn't be done. The windows would just be like a series 1 landy though.
Author:  TZAR [ Sat Dec 27, 2008 10:13 pm ]
Early 1 litres ahd them and so did the drover. Half door with a rag window.
Author:  Mike [ Sat Dec 27, 2008 11:56 pm ]
this guy told me on his the top half unbolted and the window channel came out with the frame
Author:  royce [ Sun Dec 28, 2008 12:02 am ]
no, cause the glass would flop about and break if somebody unbolted them and then wound the glass up :)
Author:  Mike [ Sun Dec 28, 2008 12:08 am ]
ok makes sense
would replacing the tack welds that hold the window frames with a bolt on bracket work?
i understand i would still have to unbolt the window from the regulator and take it out
Author:  royce [ Sun Dec 28, 2008 12:13 am ]
you probably could remove the frame from the door and get it to work but it proabbly doesnt achieve much
Author:  Mike [ Sun Dec 28, 2008 12:16 am ]
well it be like having full doors and half doors in one sort of :?
Author:  royce [ Sun Dec 28, 2008 12:20 am ]
the window frames are hardly blocking the view :wink:
Author:  Mike [ Sun Dec 28, 2008 12:46 am ]
yeah but it stops me from getting gouges in the window from opening and closing them when they are dirty
Author:  royce [ Sun Dec 28, 2008 12:48 am ]
which you cant do with the frames off anyway so you may as well leave them open
Author:  Mike [ Sun Dec 28, 2008 12:54 am ]
yeah but with the frames off i can't close them even if i want to then when i go to put the frame and window back in i can wash out the door and wn't end up with another stuffed window
Author:  kenn [ Sun Dec 28, 2008 8:14 pm ]
I think your friend had a (dare i say it )Range Rover and was living in la-la-land believing it to be a Suzuki. Why not wash out the door before you wind the window up,same result less work, or wash the window before you put it down.
Author:  TZAR [ Sun Dec 28, 2008 10:21 pm ]
possible but kinda pointless. Why not just take the seal rubbers out and then it won't scratch the window.
or take the winders off when you go off road then you can't wind them up or down.....
Author:  2stroker [ Mon Dec 29, 2008 6:21 am ]
Or buy one of these and leave the doors at home........
Author:  Mike [ Mon Dec 29, 2008 6:34 am ]
that certainly would be less work :lol:
