| Fuel pressure g16b https://auszookers.com/forum/viewtopic.php?f=5&t=36463 |
| Author: | shep [ Thu Oct 18, 2012 7:05 am ] |
| Post subject: | Fuel pressure g16b |
I need to maintain 43+\- 5 psi in the fuel rail of my vit G16 at full throttle with stock injectors and a extra jet that has a 4mm hole in it. Will be using a vitara tank. If I make a falcon or commodore pump fit in the vit tank module would that work? Any other ideas? |
| Author: | JrZook [ Thu Oct 18, 2012 9:41 am ] |
| Post subject: | Re: Fuel pressure g16b |
Does that 4mm jet have a flow rating(cc/min)? But yes a commo pump would flow more @ 3bar than a vit pump assembly. |
| Author: | canberramav [ Thu Oct 18, 2012 10:20 am ] |
In Oozuks thread he show a bosch pump that he used that was a straight swap. I used the same one on my comp truck. Can remember what tank it suits though? |
| Author: | shep [ Thu Oct 18, 2012 12:24 pm ] |
JrZook wrote: Does that 4mm jet have a flow rating(cc/min)? . Possibly, I will have a look and see what I can find. I don't want to melt my motor so would prefer not to have to work off trial and error |
| Author: | JrZook [ Thu Oct 18, 2012 2:11 pm ] |
shep wrote: JrZook wrote: Does that 4mm jet have a flow rating(cc/min)? . Possibly, I will have a look and see what I can find. I don't want to melt my motor so would prefer not to have to work off trial and error Well then spill with any extra info you are hiding. Numbers are good! |
| Author: | shep [ Thu Oct 18, 2012 4:33 pm ] |
Sticking a wet nitrous kit on a vit motor and the smallest fuel jet Is a hole about 4mm, the structions say that it needs 43 pSi to work properly. Will have a look for flow rates |
| Author: | shep [ Thu Oct 18, 2012 4:51 pm ] |
While I am at it is there any way I can arm a switch when revs are above 3000? |
| Author: | Gwagensteve [ Thu Oct 18, 2012 4:51 pm ] |
Jaycar sell RPM operated switch kits. Steve. |
| Author: | atari4x4 [ Thu Oct 18, 2012 4:59 pm ] |
http://www.dynotunenitrous.com/store/sc ... roduct=216 |
| Author: | Damo [ Thu Oct 18, 2012 5:44 pm ] |
I'd run a 2nd pump dedicated to the no^2 I look forward to the pics of bent conrods |
| Author: | britvit [ Thu Oct 18, 2012 6:21 pm ] |
Gwagensteve wrote: Jaycar sell RPM operated switch kits. Steve. ...and I know someone who can build the kit for you |
| Author: | shep [ Sat Oct 20, 2012 8:12 am ] |
Thanks britvit The only jaycar kit I can find is this one which I don't think will be any good to me. http://www.jaycar.com.au/productView.asp?ID=KC5382 |
| Author: | royce [ Sat Oct 20, 2012 9:58 am ] |
The intank pump in a vit is somewhat of a generic 38mm pump, lots of jap cars run the same size pump and aftermarket high flow ones are available that can fit in pretty easilly |
| Author: | losfer [ Sat Oct 20, 2012 10:06 am ] |
walbro gss341 255 litre per hour fuel pump rated to 500hp |
| Author: | britvit [ Sat Oct 20, 2012 11:00 am ] |
shep wrote: Thanks britvit The only jaycar kit I can find is this one which I don't think will be any good to me. http://www.jaycar.com.au/productView.asp?ID=KC5382 I think this is the kit you need..... http://www.jaycar.com.au/productView.as ... TID=965#11 Unfortunately the fella who I know who can build it for you is a shameless coke addict..... .....it's gonna cost you at least a couple of 2 litre bottles
| Author: | shep [ Sat Oct 20, 2012 12:10 pm ] |
losfer wrote: walbro gss341 255 litre per hour fuel pump rated to 500hp Thanks mate. Will the stock vitara injectors and pressure regulator be able to handle the pump when it isn't using nitrous? |
