I picked up a g16b out of a vitara and have started stripping the loom down and ran into a slight problem. The motor has a built in coil. That is the dizzy and coil are built together. And so the wiring diagrams i have found don't match.
I thought maybe it was a simple case that the wires would be the same and just all run to the dizzy. But sadly it is not the case. The only thing i can think of is hook all the loom up and strip it down only leaving me with the motor bits. Just didn't want to do this if i can find a diagram.
Yeah thanks for the help guys. But the bit i'm struggling with is the actually diagram. Half the wire colors and locations match the other half doesn't :/ I've gone through all the diagrams on suzukiinfo but none as the same. Guess i'll just have the foolow all the plugs back and remove the rest.
Users browsing this forum: Google [Bot] and 61 guests
