https://auszookers.com/forum/
Oil coming from speedo cable.
https://auszookers.com/forum/viewtopic.php?f=5&t=36578
Author:  jonozuk666 [ Tue Oct 23, 2012 4:58 am ]
Post subject:  Oil coming from speedo cable.
just wondering if anyone has ever heard of oil leaking from the spedo cable behind the dash.
it drips about every 5 seconds when on the highway down into the footwell.
any ideas what could be causing this?
Author:  djed [ Tue Oct 23, 2012 5:52 am ]
Post subject:  Re: oil coming from spedo cable
?? blocked breather, over filled box
Author:  jonozuk666 [ Wed Oct 24, 2012 6:23 pm ]
Post subject:  Re: Oil coming from speedo cable.
how can i check if the breather is blocked?
there is a cap over it like on the diffs would i need to bust this off?
Author:  missmyljdaze [ Wed Oct 24, 2012 6:36 pm ]
you might as well go the whole hog- remove the cap, check the breather is clear- then fit remote breathers for your gearbox, transfer case, and diffs.
not a terribly difficult or pricey job- there is a post here somewhere showing how its done.
check the details on how its done, collect the bits you need- then all you need is a couple of hours spare time to do it.
Author:  BlueSuzy [ Wed Oct 24, 2012 10:03 pm ]
Check breather.
Check speedo drive gear o-ring
Never see that before!
