| I bought 2 Spartan Lockers https://auszookers.com/forum/viewtopic.php?f=5&t=36579 |
| Author: | shiv [ Tue Oct 23, 2012 5:03 am ] |
| Post subject: | I bought 2 Spartan Lockers |
Im going to try and fit them myself. I bought chromos for the front to. Any hints or links that i could use which would be helpful? I had a search but couldnt find much on the tech side of things. Any additional things i need or a guide would be great Regards Shiv |
| Author: | neofitou [ Tue Oct 23, 2012 5:13 am ] |
| Post subject: | Re: I bought 2 Spartan Lockers |
Leave the shims out. Take your foot off the accelerator when you want to turn. |
| Author: | shiv [ Tue Oct 23, 2012 6:04 am ] |
neofitou wrote: Leave the shims out. Take your foot off the accelerator when you want to turn. Reason for leaving shims out? |
| Author: | SierraDan [ Tue Oct 23, 2012 6:23 am ] |
Its tight as fuck. Basically.a spool. Keep them but for when it wears in and yiu can tighten it bsck up |
| Author: | christover1 [ Tue Oct 23, 2012 7:05 am ] |
The Spartan don't use shims, and instructions say remove original stock shims. (Which can hide and appear to be not there) |
| Author: | BlueSuzy [ Tue Oct 23, 2012 8:11 am ] |
christover1 wrote: The Spartan don't use shims, and instructions say remove original stock shims. (Which can hide and appear to be not there) Yes. I bought one for a mate. Looks simple. Nothing to fark up except backlash of the crownwheel/bearing preload again. |
| Author: | nato78 [ Tue Oct 23, 2012 8:16 pm ] |
I'm surprised you didn't give Him the link to your write up christover, it's what I used to do my install, heaps more helpful than the instructions that came with the locker viewtopic.php?f=17&t=15661 |
| Author: | christover1 [ Tue Oct 23, 2012 8:37 pm ] |
nato78 wrote: I'm surprised you didn't give Him the link to your write up christover, it's what I used to do my install, heaps more helpful than the instructions that came with the locker viewtopic.php?f=17&t=15661 I was feeling lazy and busy. |
| Author: | shiv [ Wed Oct 24, 2012 5:44 am ] |
Thanks nato. Much appreciated |
| Author: | nato78 [ Wed Oct 24, 2012 6:24 am ] |
No probs... Christover did all the hard work, I just copy and pasted |
| Author: | 31zook [ Wed Oct 24, 2012 6:28 am ] |
Did you buy two rear Spartan lockers? |
| Author: | neofitou [ Wed Oct 24, 2012 7:08 am ] |
I used two of them in my Sierra, I had 2 4pin (NT) carriers though. |
| Author: | SierraDan [ Wed Oct 24, 2012 7:28 am ] |
31zook wrote: Did you buy two rear Spartan lockers? They use the side gears. Doesnt matter what diff they go in. |
| Author: | shiv [ Wed Oct 24, 2012 10:37 am ] |
I didnt pay attention to that. Just thought the 26 spline rear lock fit front as well with chomos |
| Author: | defibros [ Wed Oct 24, 2012 11:05 am ] |
what diff oil is good for spartan lockers to eliminate those nasty sounds? |
| Author: | christover1 [ Wed Oct 24, 2012 11:44 am ] |
I use nulon 80/90 in both my diffs (front Spartan, rear Lockrite) No nasty noises from mine in road use. Occassional clunk out of front end in off road 3 point turns (Though selecting 2wd usually avoids that) I am hard of hearing, so may be different to others. But can't hear noises over engine and normal drive train sounds. Except for that occassional front end clunk. |
| Author: | SierraDan [ Wed Oct 24, 2012 11:56 am ] |
Mine was no louder than a stock exhaust at idle after s month |
| Author: | defibros [ Wed Oct 24, 2012 12:04 pm ] |
yeah i read on here that the LSD diff oil will help reduce sound.. i got a loud "clunk" noise for the first time yesterday when i am making a right turn....shock of my life! |
| Author: | SierraDan [ Wed Oct 24, 2012 12:38 pm ] |
defibros wrote: yeah i read on here that the LSD diff oil will help reduce sound.. i got a loud "clunk" noise for the first time yesterday when i am making a right turn....shock of my life! Helps a bit. But you really need to just drive it until it wears in. If its brand new, its gonna clunk like a bitch for a while yet. |
| Author: | nato78 [ Wed Oct 24, 2012 1:00 pm ] |
Mine clunks more now than it did when it was new... Either that or it was that tight when I first put it in that it didn't unlock at all?!! Maybe time to change the diff oil. Anyone want to weld a nut on my diff filler plug for me, I rounded out the hole last time I went to change the oil |
| Author: | SierraDan [ Wed Oct 24, 2012 1:12 pm ] |
Need to put those shims in maybe. |
| Author: | DarkHorse [ Wed Oct 24, 2012 2:32 pm ] |
Nath if you can get it to Leichhardt (where I met you after Coffin) when I'm in town we could zap a nut on for you. Timing will be the issue. |
| Author: | nato78 [ Wed Oct 24, 2012 5:49 pm ] |
DarkHorse wrote: Nath if you can get it to Leichhardt (where I met you after Coffin) when I'm in town we could zap a nut on for you. Timing will be the issue. Cheers mate, but I've got a stick welder at home, I just can't weld for shit (and I've been too lazy Dan, I don't think it needs shimming, it's a bit noisy but its certainly not undriveable |
