It is currently Fri Nov 06, 2026 6:02 pm
Vehicle: SJ70 1993
Post Posted: Tue Oct 23, 2012 5:03 am
Im going to try and fit them myself.
I bought chromos for the front to.
Any hints or links that i could use which would be helpful?
I had a search but couldnt find much on the tech side of things. Any additional things i need or a guide would be great
Regards Shiv
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Tue Oct 23, 2012 5:13 am
Leave the shims out.
Take your foot off the accelerator when you want to turn.
Vehicle: SJ70 1993
Post Posted: Tue Oct 23, 2012 6:04 am
Reason for leaving shims out?
Post Posted: Tue Oct 23, 2012 6:23 am
Its tight as fuck. Basically.a spool. Keep them but for when it wears in and yiu can tighten it bsck up
Post Posted: Tue Oct 23, 2012 7:05 am
The Spartan don't use shims, and instructions say remove original stock shims.
(Which can hide and appear to be not there)
Post Posted: Tue Oct 23, 2012 8:11 am
Yes. I bought one for a mate. Looks simple. Nothing to fark up except backlash of the crownwheel/bearing preload again.
Vehicle: Yamaha scooter, 50cc
Post Posted: Tue Oct 23, 2012 8:16 pm
I'm surprised you didn't give Him the link to your write up christover, it's what I used to do my install, heaps more helpful than the instructions that came with the locker
viewtopic.php?f=17&t=15661
Post Posted: Tue Oct 23, 2012 8:37 pm
I was feeling lazy and busy.
:oops:
Vehicle: SJ70 1993
Post Posted: Wed Oct 24, 2012 5:44 am
Thanks nato. Much appreciated
Post Posted: Wed Oct 24, 2012 6:24 am
No probs... Christover did all the hard work, I just copy and pasted :mrgreen:
Post Posted: Wed Oct 24, 2012 6:28 am
Did you buy two rear Spartan lockers?
Post Posted: Wed Oct 24, 2012 7:08 am
I used two of them in my Sierra, I had 2 4pin (NT) carriers though.
Post Posted: Wed Oct 24, 2012 7:28 am
They use the side gears. Doesnt matter what diff they go in.
Vehicle: SJ70 1993
Post Posted: Wed Oct 24, 2012 10:37 am
I didnt pay attention to that. Just thought the 26 spline rear lock fit front as well with chomos
Post Posted: Wed Oct 24, 2012 11:05 am
what diff oil is good for spartan lockers to eliminate those nasty sounds?
Post Posted: Wed Oct 24, 2012 11:44 am
I use nulon 80/90 in both my diffs (front Spartan, rear Lockrite)
No nasty noises from mine in road use.
Occassional clunk out of front end in off road 3 point turns
(Though selecting 2wd usually avoids that)
I am hard of hearing, so may be different to others.
But can't hear noises over engine and normal drive train sounds.
Except for that occassional front end clunk.
Post Posted: Wed Oct 24, 2012 11:56 am
Mine was no louder than a stock exhaust at idle after s month
Post Posted: Wed Oct 24, 2012 12:04 pm
yeah i read on here that the LSD diff oil will help reduce sound.. i got a loud "clunk" noise for the first time yesterday when i am making a right turn....shock of my life!
Post Posted: Wed Oct 24, 2012 12:38 pm
Helps a bit. But you really need to just drive it until it wears in. If its brand new, its gonna clunk like a bitch for a while yet.
Post Posted: Wed Oct 24, 2012 1:00 pm
Mine clunks more now than it did when it was new... Either that or it was that tight when I first put it in that it didn't unlock at all?!! Maybe time to change the diff oil. Anyone want to weld a nut on my diff filler plug for me, I rounded out the hole last time I went to change the oil :evil:
Post Posted: Wed Oct 24, 2012 1:12 pm
Need to put those shims in maybe.
Post Posted: Wed Oct 24, 2012 2:32 pm
Nath if you can get it to Leichhardt (where I met you after Coffin) when I'm in town we could zap a nut on for you.
Timing will be the issue.
Post Posted: Wed Oct 24, 2012 5:49 pm
Cheers mate, but I've got a stick welder at home, I just can't weld for shit (and I've been too lazy :oops: )
Dan, I don't think it needs shimming, it's a bit noisy but its certainly not undriveable
Users browsing this forum: No registered users and 85 guests
