It is currently Fri Nov 06, 2026 5:46 pm
Post Posted: Wed Oct 24, 2012 8:09 pm
hi all just wonting some transfer reduction gears for my 99 jimny where can i get some?
thanks guyes cheers
Post Posted: Wed Oct 24, 2012 8:18 pm
APIO 8O
Vehicle: LJ50V, SJ70
Post Posted: Wed Oct 24, 2012 10:49 pm
APIO: http://translate.googleusercontent.com/ ... 3W4J1rI1-Q 58% Reduction in Low Range only.
Trial Jimny: http://www.trialjimny.com/intro.html Reduction of 24% in BOTH High and Low Range.
Can fit both styles of reduction gears for an expensive but mega-low transfer!! :shocked:
If you'd like to replace the Jimny Transfer Case with a Sierra one to take advantage of the much wider choices of gearing ratios (2 different factory ratios and 7 aftermarket ratios), then Jimnybits makes the kit to make the swap, but they have dropped them from their website: http://www.jimnybits.co.uk/shop/index.php. Mention Auszookers for your advertising discount.
Vehicle: Suzuki Jimny 2010
Post Posted: Thu Oct 25, 2012 11:31 am
Offroad armoury also do a wt swap kit, and if you order it before the end of October you'll get 15% off ;)
Post Posted: Thu Oct 25, 2012 7:13 pm
ok than well i allready have a sierra transfer hear whats involved in the swap will i have to cut the floor out more what about the speedo cable and other mods needed?
pic's or links to other threads would be great thanks.
Vehicle: 2011 jimny
Post Posted: Thu Oct 25, 2012 7:35 pm
i am interested in that apio gear as im happy with my high range but want my lower, well lower would it be hard to fit?
Post Posted: Thu Oct 25, 2012 7:59 pm
So I suppose you've also done your currency conversion and worked out that 192,000 Yen is about AU$2400?
Post Posted: Thu Oct 25, 2012 8:46 pm
And that doesn't even include shipping!!!!!!!
Ridonkulous!
Vehicle: 2011 jimny
Post Posted: Thu Oct 25, 2012 10:22 pm
ohh woww!! that sucks,was exactly what i was looking for
Post Posted: Thu Oct 25, 2012 11:59 pm
viewtopic.php?f=17&t=30820
Post Posted: Fri Oct 26, 2012 5:52 am
ok thanks alot guys
Users browsing this forum: Google [Bot] and 54 guests
