| Fitting bigger tyres to jimny without ripping front bar off https://auszookers.com/forum/viewtopic.php?f=5&t=36642 |
| Author: | JCB [ Thu Oct 25, 2012 2:26 pm ] |
| Post subject: | Fitting bigger tyres to jimny without ripping front bar off |
I went to fit some bigger tyres on my new jimny (225/75/15). I had to take them off as they would have ripped the bar off. How have you guys gone about it? Photos and advice would be good. Cheers! |
| Author: | Blakey [ Thu Oct 25, 2012 2:28 pm ] |
| Post subject: | Re: Fitting bigger tyres to jimny without ripping front bar |
cut the front bar up like most Jimny owners have to fit larger tyres |
| Author: | 31zook [ Thu Oct 25, 2012 3:18 pm ] |
Grab some masking tape and a jig saw. Be careful and it will look pretty stock. |
| Author: | zukenutter [ Thu Oct 25, 2012 9:11 pm ] |
Any suspension lift on your Jimny? I'll assume you've got wide offset rims otherwise 225s shouldn't contact the bumper, rear of the flare yes but not the bumper. Or do you have a ARB bar |
| Author: | JCB [ Fri Oct 26, 2012 6:54 am ] |
Im putting in a 2 inch lift but when i had it on the hoist i lifted it about 2 inches and it was still going to do the same thing. Yep -13 offset... Nope- standard front bar. |
| Author: | BlueSuzy [ Fri Oct 26, 2012 6:59 am ] |
Move your bar 3" forward |
| Author: | zukenutter [ Fri Oct 26, 2012 7:13 am ] |
JCB wrote: Im putting in a 2 inch lift but when i had it on the hoist i lifted it about 2 inches and it was still going to do the same thing. Yep -13 offset... Nope- standard front bar. You started arse-about Your problem is mainly coming from the -13 rims as the arc they follow when steering is different to stock. If you can afford it, go get the lift before you cut, unless you plan to cut anyway then go for it. I cut my bar for approach angle, not for tyre clearance. I ran my last Jimny with the standard bar, 60mm lift and 235/75R15 for years without any contact with the bar. ... Hang on, what model Jimny ? |
| Author: | zukenutter [ Fri Oct 26, 2012 7:15 am ] |
Ah, just checked your profile, 2010, so the big low bumper... Cut, cut, cut. First thing I did with my new one was get rid of that bumper. |
| Author: | JCB [ Fri Oct 26, 2012 9:19 am ] |
I have a 50mm lift kit sitting in the boot which i will be fitting tomorrow. I just tried the tyres yesterday to see if they would clear and they wont... haha. Yeah I will have to do the chop. Just wanted to see how others have done it with what method etc. Dont really want to fork out more money for bullbar or anything... |
| Author: | zukenutter [ Fri Oct 26, 2012 9:23 am ] |
I used an electric hack saw to do mine, works well. |
