It is currently Fri Nov 06, 2026 7:30 pm
Post Posted: Sat Oct 27, 2012 10:38 am
just wondering if anyone knows who makes the Suzuki differentials
companies Nissan have Hitachi and Fuji heavy industries make theirs
The H series and R series diffs
The sierra diff ring gear size is listed as 6.9 inches 175.25 mm
Ring Gear Bolts 10 - 10mm bolts
Ring Gear Diameter 6.90 Inches
Pinion Shaft Diameter/Splines 1.379"/26
Axle Shaft Diameter / Splines .940 / 22 (Front)
1.05 / 26 (Rear)
Axle Tube Material / Diameter / Wall Thickness HREW / 2.56 / .120
Gear Ratio 3.73
Available Aftermarket Ratios 4.57, 5.38
Carrier Breaks None
Recommended Max Tire Size 32-Inches
Pinion Bearing Preload 7.8-14.7 in-lbs
Backlash .004-.006 in.
Ring Gear Torque 58-65 lbs-ft
Carrier Bearing Cap Torque 51-72 lbs-ft
http://zukioffroad.com/Tech_Library/sam ... ions.shtml
Online
Post Posted: Sat Oct 27, 2012 10:43 am
Why does it matter?
I imagine it's unlikely to be Borg Warner, as I think the Japanese Warner business is Aisin Warner, who make the freewheeling hubs, auto gearbox etc. My guess would it would be Aisin Warner.
Steve
Post Posted: Sat Oct 27, 2012 10:48 am
are Aisin & Borg Warner Brothers?
Online
Post Posted: Sat Oct 27, 2012 10:49 am
Just don't talk about nigel warner, the red headed stepchild :D
:rofl:
Post Posted: Sat Oct 27, 2012 2:28 pm
Suzuki diffs have the Hitachi symbol cast into them.
Online
Post Posted: Sat Oct 27, 2012 3:31 pm
Just had a look myself and so they do.
Post Posted: Sun Oct 28, 2012 5:31 am
Holy shit!!! The mexicans actually agreed on something :shocked:
Post Posted: Sun Oct 28, 2012 6:22 am
hillbilly wrote:
....i just think its clever how they cast them ''bent''
What drugs are you on? Please tell me so I know which ones not to take.
Post Posted: Mon Oct 29, 2012 10:49 am
Good to see you know your diffs. If you are thinking of the housing than its fabricated, not cast. Only the center section is cast.
Post Posted: Mon Oct 29, 2012 11:09 am
Had a feeling it was a Hitachi as I looked at a friends datsun 1200 ute and looked similar and he was after an LSD so figured he could probably use a Suzi one but the 1200 ute is H165 meaning 165mm most likely or 10mm out if the suzi one is 175mm.
Now on my side of things I finished a modded g16b conversion into a 99 model carry and the diff has started to go apeshit from the torque and wheel spin no thanks to my spirited driving style since I fit a bigger exhaust.
Its a piddly 8 bolt diff of some kind so thinking its the same as the early Sierras and 4.33 something ratio.
Id like to fit a 4.1 or 3.9 as the engine pulls even from 4th gear in almost any revvs and could do with 5th gear having more legs rather than revs. I will have to make sure I change my lead foot as the bigger diameter stickier 185/65/14s also wont help destroy the diff sooner.
Users browsing this forum: No registered users and 92 guests
