https://auszookers.com/forum/
Suzuki Differentials who the hell makes them Hitachi or BW?
https://auszookers.com/forum/viewtopic.php?f=5&t=36686
Author:  datso [ Sat Oct 27, 2012 10:38 am ]
Post subject:  Suzuki Differentials who the hell makes them Hitachi or BW?
just wondering if anyone knows who makes the Suzuki differentials
companies Nissan have Hitachi and Fuji heavy industries make theirs
The H series and R series diffs
The sierra diff ring gear size is listed as 6.9 inches 175.25 mm
Ring Gear Bolts 10 - 10mm bolts
Ring Gear Diameter 6.90 Inches
Pinion Shaft Diameter/Splines 1.379"/26
Axle Shaft Diameter / Splines .940 / 22 (Front)
1.05 / 26 (Rear)
Axle Tube Material / Diameter / Wall Thickness HREW / 2.56 / .120
Gear Ratio 3.73
Available Aftermarket Ratios 4.57, 5.38
Carrier Breaks None
Recommended Max Tire Size 32-Inches
Pinion Bearing Preload 7.8-14.7 in-lbs
Backlash .004-.006 in.
Ring Gear Torque 58-65 lbs-ft
Carrier Bearing Cap Torque 51-72 lbs-ft
http://zukioffroad.com/Tech_Library/sam ... ions.shtml
Author:  Gwagensteve [ Sat Oct 27, 2012 10:43 am ]
Post subject:  Re: Suzuki Differentials who the hell makes them Hitachi or
Why does it matter?
I imagine it's unlikely to be Borg Warner, as I think the Japanese Warner business is Aisin Warner, who make the freewheeling hubs, auto gearbox etc. My guess would it would be Aisin Warner.
Steve
Author:  atari4x4 [ Sat Oct 27, 2012 10:48 am ]
are Aisin & Borg Warner Brothers?
Author:  Gwagensteve [ Sat Oct 27, 2012 10:49 am ]
Just don't talk about nigel warner, the red headed stepchild :D
Author:  Scrawny [ Sat Oct 27, 2012 10:49 am ]
:rofl:
Author:  joeblow [ Sat Oct 27, 2012 2:28 pm ]
Suzuki diffs have the Hitachi symbol cast into them.
Author:  Gwagensteve [ Sat Oct 27, 2012 3:31 pm ]
Just had a look myself and so they do.
Author:  zukmeista [ Sun Oct 28, 2012 5:31 am ]
Holy shit!!! The mexicans actually agreed on something :shocked:
Author:  kenn [ Sun Oct 28, 2012 6:22 am ]
hillbilly wrote:
....i just think its clever how they cast them ''bent''
What drugs are you on? Please tell me so I know which ones not to take.
Author:  joeblow [ Mon Oct 29, 2012 10:49 am ]
Good to see you know your diffs. If you are thinking of the housing than its fabricated, not cast. Only the center section is cast.
Author:  datso [ Mon Oct 29, 2012 11:09 am ]
Had a feeling it was a Hitachi as I looked at a friends datsun 1200 ute and looked similar and he was after an LSD so figured he could probably use a Suzi one but the 1200 ute is H165 meaning 165mm most likely or 10mm out if the suzi one is 175mm.
Now on my side of things I finished a modded g16b conversion into a 99 model carry and the diff has started to go apeshit from the torque and wheel spin no thanks to my spirited driving style since I fit a bigger exhaust.
Its a piddly 8 bolt diff of some kind so thinking its the same as the early Sierras and 4.33 something ratio.
Id like to fit a 4.1 or 3.9 as the engine pulls even from 4th gear in almost any revvs and could do with 5th gear having more legs rather than revs. I will have to make sure I change my lead foot as the bigger diameter stickier 185/65/14s also wont help destroy the diff sooner.
