Joined: Sun May 23, 2010 3:06 am Posts: 51 Location: peaches
Posted: Sun Oct 28, 2012 4:32 pm
Got a suzuki grand vitara 1999, broke the rear door handle. Pretty common I hear. So bought one of those unbreakable one from ebay. Broke that too. Are there any other options ?
I believe the "unbreakable" handles are marketed by ODA.
There's a design flaw in the OEM handle assembly that allows them to flex & break - the OEM handle uses two pivot pins, and this allows the "fixed" part (that bolts to the door) to flex when you lift the moving part - if the fixed part flexes too much, the moving part breaks - replace the two pins with a single full length pin and you eliminate (or at least significantly reduce) the flex.
Users browsing this forum: No registered users and 68 guests
