| Author |
Message |
Joshyboy26
Joined: Thu Sep 01, 2011 11:48 pm Posts: 814 Location: kinglake, VIC
 Posted: Mon Oct 29, 2012 5:48 pm |
hey guys ive had a search but havent come up with much suzuki sierra wt 89 anyone know the size of the shifter ball that goes in on the other side of the detent ball when your putting your transfer case back together? I seem to have misplaced mine but have a few random ones floating around. would an 8mm dia ball be close enough or does it have to be exact
thanks in advance
Scales
Joined: Mon May 30, 2011 9:28 am Posts: 2233 Location: Townsville
 Posted: Mon Oct 29, 2012 5:56 pm |
rekon itd have to be pretty much exact. When I rebuilt mine there was 2 different size's and they were bullshit close to each other in dia.
I could be 100% wrong though. not an expert in sierra cases apart from what ive done with my own.
gregc
Joined: Wed Sep 21, 2011 9:09 am Posts: 177 Location: melbourne
9.48mm for the gear shifter detent ball.
7.91mm for the shifted fork detents.
Joshyboy26
 Posted: Mon Oct 29, 2012 6:05 pm |
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13017 Location: Melbourne
 Posted: Mon Oct 29, 2012 6:13 pm |
gregc wrote: 9.48mm for the gear shifter detent ball.
7.91mm for the shifted fork detents. Bwahahaha  I know how you know that. Transfer case apart perchance?  Steve.
Scales
 Posted: Mon Oct 29, 2012 6:32 pm |
:goodtech:
LOL bound to come up again. i know I nearly lost my balls.... *snigger*
303zuke
Vehicle: LJ50V, SJ70
 Posted: Mon Oct 29, 2012 10:57 pm |
7.91mm for the shifted fork detents. Sounds very close to what the Amurricuns would call 3/8" and 5/16"?
tazmanier
Joined: Fri Jun 26, 2009 11:30 pm Posts: 47 Location: gerringong
Vehicle: 89 SWB zuke
 Posted: Mon Oct 29, 2012 11:23 pm |
303zuke wrote: Sounds very close to what the Amurricuns would call 3/8" and 5/16"?  WOW 303, did you know they were imperial before hand? Cause that’s an awesome pickup. I feel sad now however. No more boasting Suzuki was so ahead of its time being completely metric.
Joshyboy26
 Posted: Tue Oct 30, 2012 6:10 am |
well I have two of them. im hoping the third is somewhere in the gunge on the bottom of the parts washer haha
Gwagensteve
 Posted: Tue Oct 30, 2012 6:18 am |
tazmanier wrote: 303zuke wrote: Sounds very close to what the Amurricuns would call 3/8" and 5/16"?  WOW 303, did you know they were imperial before hand? Cause that’s an awesome pickup. I feel sad now however. No more boasting Suzuki was so ahead of its time being completely metric. I think you'll find the seat belt bolts aren't metric either, as per SAE regulations. Steve
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Tue Oct 30, 2012 7:04 am |
Every new car in Aust has at least 1 af bolt
_________________ JEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEP
Blakey
Joined: Sun Mar 04, 2012 6:11 pm Posts: 464 Location: Brisbane, Petire
 Posted: Tue Oct 30, 2012 8:08 am |
pretty sure there should be 4 dentent balls. 2 removed from outside the case and 2 removed when the shifter rods are removed. as well as 2 or 3 springs cant be sure till i look at that one with what i have in parts at home. I have my case appart. doing a rebuild on it. but got stuck without a press to remove the front output shaft from the case.
Joshyboy26
 Posted: Tue Oct 30, 2012 1:03 pm |
I dont have a press you shouldnt need one just a few love taps or bearing pullers
