It is currently Fri Nov 06, 2026 5:59 pm
Post Posted: Wed Oct 31, 2012 9:40 am
I just need to check that I have got this right - Most likely not :?
Turn the ign on and the light comes on.
Start engine and light goes off if all is well.
If problem is sensed light flashes a code sequence such as 4 flashes delay 1 flash repeated = code 41.
If the engine does not start because there is a problem it just stays on and does nothing useful :evil:
Is this correct? If so what bloody use is it when you have a engine won't start problem like I do?
Post Posted: Wed Oct 31, 2012 9:56 am
you need to bridge the diagnostic plug to retrieve the code, it won't do it with the just the ignition on, i'm not 100% sure where the plug is located on the G16b, but on mine it's near the air filter in the engine bay.
1/2 way down this page i have attached a word document on how to pull the codes from a j20a vitara. viewtopic.php?f=5&t=6451&hilit=j20a+error+codes
if you disconnect the battery it will clear the codes.
Post Posted: Wed Oct 31, 2012 10:32 am
OK - Downloaded and read that - All/any codes I had will now be gone so - When I put the battery back in and try to start it again will it re-write any codes if there are any found in the pre-flight test?
On that list I guess the PD numbers will only show if you have the plugin tool thingy?
Post Posted: Wed Oct 31, 2012 10:37 am
as far as i know there is no "pre-flight test"... usually it needs to have been running for it to log the codes.
Post Posted: Wed Oct 31, 2012 10:42 am
The manual suggests there is one and there is a noticeable delay while it tests and turns the power mode and OD lights on/off etc. So I thought the computer was checking things
Post Posted: Wed Oct 31, 2012 10:45 am
ahh yeah that sounds about right. :oops:
Post Posted: Wed Oct 31, 2012 11:10 am
I guess the best way to find out is put the battery in (when charged) turn it over a bit and then check the codes - If any - with the jumper wire................................ If I can find the plug - I think it is near the battery, I seem to remember seeing a plug with a cover on it there abouts.
Post Posted: Thu Nov 01, 2012 11:14 am
The ECU will detect any failed sensors within seconds after the ignition is switched on, and many of them without cranking, starting or running - stuff like temp & airflow are checked for over or under voltage conditions which would indicate short or open circuits, as well as values that are improbable. Other sensors - cam position, crank position and so on, need the engine to be cranked before it will sense - yet others like the vehicle speed sensor, need it to be driven, before it will detect a failure
Rhinoman's web pages are about the best source of reliable information on how this stuff works.
Put the battery in & put the jumper in, you get a 12 flash (to say the ECU has not detected any failures), if there are any codes detected, the light will flash them, next crank the engine with the jumper in place - some ignition related failures will only show if you do it this way.
Last but not least, you can, under certain circumstances, have a failed ECU - injector drivers - or injector wiring - and you'll never get a start or an error code, the only way to pick that up is with a NOID light.
Post Posted: Thu Nov 01, 2012 11:25 am
Thank you for that information - Where are the Rhinoman's web pages?
Post Posted: Thu Nov 01, 2012 11:30 am
http://www.rhinopower.org/diag/cel.html
Users browsing this forum: Google [Bot] and 74 guests
